It is currently Mon Jun 08, 2026 6:45 am
 Post subject: Painting wheels
PostPosted: Sun Jan 18, 2009 8:36 am
I want to paint my own wheels (white). Any suggestions on what kind of paint is the best. Also what do you suggest I use for the clear coat?
Thanks
 Post subject: Re: Painting wheels
PostPosted: Sun Jan 18, 2009 9:21 am
Go to your parts store they will have paint specifically for wheels. I've never used it so I'm not familiar with any one brand over another.
PostPosted: Sun Jan 18, 2009 11:27 pm
viewtopic.php?f=7&t=18374
Loves me some search function. Unfair though because I remember posting about this topic before.
I finally got the paint for my wheels from Summit Racing. It ended up being VHT Rally Silver.
PostPosted: Mon Jan 19, 2009 6:23 pm
You could find a place that does powder coat. That is how i usually end up doing mine. Though were I go, they only have basic colors (Black, silver, white, school bus yellow).
2003 F250 7.3L
1975 Luv
PostPosted: Tue Jan 20, 2009 12:37 am
i work for a wheel repair company and we paint and polish and machine wheels all day i use an actual spray gun by sata wheels are primered painted and cleared just like a car all the paints are du pont
PostPosted: Wed Jan 21, 2009 8:41 pm
ok i have some rusty chrome wheels could i paint mine? or do i need to do something special?
do you believe in LUV at first sight or does one have to drive by you again?
76' stepside mikado w/sunroof
PostPosted: Wed Jan 21, 2009 8:48 pm
Quote:
you will have to blast all the chrome off, then prime and paint them. You can't even rough up chrome and get paint to stick permanently.
Got that info from another forum, but that is what i was thinking also.
2003 F250 7.3L
1975 Luv
PostPosted: Wed Jan 21, 2009 11:22 pm
chrome wheels are different because paint wont adhere to them very well but there is some stuff call bulldog adhesive promoter that comes in a spray can that works great
PostPosted: Fri Jan 23, 2009 2:58 pm
I had ok luck painting a set of rusty chrome wheels even with tires on them I got all the rust and loose chrome off with a wire wheel and then roughed/scratched them up some with some garnet coated sand paper. (very hard abrasive paper) I didn't do anything too special, just primed and flat black but they turned out ok and have held up for over a year of Oregon liquid weather. I guess it depends on how good you expect them to turn out and how long you want them to last. I expect mine will look good for another year or so and then start to rust through again.
PostPosted: Sat Jan 24, 2009 4:14 pm
haha sounds good to me as my truck is rattle can flat black right now... so i cant see a problem with it. ill try it out when i get some time and its not raining...
PostPosted: Sat Jan 24, 2009 4:35 pm
I pulled the bed off and plan to have is sandblasted when the weather permits. The guy told me he would make a deal on blasting the wheels while he is doing the bed. I was going to hand sand them or use a wire brush on my drill, but blasting sounds easier. I will post pics when it gets done. I plan to just rattle can the wheels after the sandblasting.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 57 guests
