It is currently Mon May 25, 2026 10:33 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: good deal but????
PostPosted: Sun Nov 16, 2008 11:08 am
thats awesome that does look like it fits good! what is the pieces of angle iron in the front for your radiator or?
PostPosted: Sun Nov 16, 2008 12:58 pm
yes for the rad. but im totaly redoing the last set up i had moved the motor back 6in. but i am 6ft 4in tall and 280lbs and it was to tight for me and im prostreeting it now so its all getting moved back forward 6 to 8 in.i plan on posting alot of picks along the way i realy wish i would have taken pics when i put the mustang front under it but that was 10 years ago 8O dang its been a long time in the making i am 36 now and i got this luv when i was 17 and the ac still worked but thats long gone :( it was the first auto tras luv i had ever seen dang i need to stop thinking about it im old lol
if ya always keep ur nose to the grindstone ur gona end up with no nose
if ya think ya cant you are right
PostPosted: Thu Dec 11, 2008 6:34 pm
hey tj I am about ready to fabricate my steering I am pulling the engine and transmission. I was wondering about dimensions if possible? also did you have to cut your steering shaft if so what parts did you add?
Thanks in advance
PostPosted: Sun Dec 21, 2008 7:33 pm
ok so we have the stock steering out! Took are measurements before. the rack and pinion is on a bracket ready to weld it to the ifs x-member save that for tomorrow. I seen that blutoyboy's rack and pinion setup he used 2" flat-bar to make his bracket so we used that idea thanks to him! maybe different if we had a lathe.
all I really need to do now is get it mounted and will need to pickup a double steering u-joint for the angle its at, it may bind otherwise with two single u-joints? we will test it with a dowel to figure out I also have another luv column.
oh and thanks TJ the tie rods I do see a little difference they are a little fatter than the luvs so yes a reamer would be nice as well! thanks for your help I can use any information
the rack sits nicely in the luv and will make a day and night difference
really sorry I don't have pictures for you all.
SOooooon!
PostPosted: Sun Dec 21, 2008 11:52 pm
The double joint will work good in this setup.If you look at the pics close you can see i only used two but the top one is welded and goes in the fire wall all this to get the most clearance.
PostPosted: Mon Dec 22, 2008 12:16 am
oh ok. I just couldn't figure out some of your pics I was like :econfused but I remember now the one pic did look like a shot of the firewall and I think I seen that your shaft went under the engine mount? yeah no kidding you have a bigger engine with little space.
we found a heim joint that will fit the shaft for support!!! so I don't have to buy that
ebay has double d double steering u-joint for $99
PostPosted: Mon Dec 22, 2008 8:11 am
The intermediate shaft is a piece of the stock steer shaft that i ground the flats to make it a double D and fits perfect.
PostPosted: Mon Dec 22, 2008 8:29 pm
ok we both got the rack mounted and its going to clear engine and crossmember and easy access to bolts as well we used 2" x 1/4" flat bar for our mount like blutoyboy's but a little different
I drew it on mspaint since no pictures
haha enjoy
PostPosted: Tue Dec 23, 2008 8:12 pm
ok well I have good news tomorrow I get a double U-joint tomorrow a man my father knows was hanging on to some from an old swap meet. I ll have to return the favor!
So tomorrow I will be busy setting it up and going to make the double d shaft
PostPosted: Sun Dec 28, 2008 11:25 pm
woo hoo! close to being done with the steering!
my dad may let me use his camera tomorrow I really want to show our progress
PostPosted: Mon Dec 29, 2008 1:27 am
Cool looking forward to see the pictures.
PostPosted: Mon Dec 29, 2008 1:54 pm
its not complete in the pictures I have put the bolts in two parts of the shaft
but just a taste!
PostPosted: Mon Dec 29, 2008 2:20 pm
we had to take two steering shafts we received from a friend and disassemble. we used every bit of them!!!
we took the dd shaft out of its fitting pipe and also take the two u-joints and make a double steering u-joint 8O to take out the bind it was necessary 8)
the other steering shaft had the dd pipe to fit our dd shaft so we decided to weld our u-joints carefully using straight edge and had a bucket of water handy to submerge
to get the two u-joints to be center there was a splined narrower shaft already welded on both of the u-joints so we cut the one off to get our centering hole and cut the other one just short enough to fit that hole and it fit! so bingo bango
we used the 3/4" id pipe that was already welded to the one side of the u-joint to connect to my stock steering
we also had an extra heim joint so we welded it around the tube that sticks out the firewall to take out the play
here is some more pics of the support heim joint
PostPosted: Mon Dec 29, 2008 7:32 pm
well ok ran into a little problem but can be dealt with later is a bind in the double u joint we put together it can only go 30 degrees max before it starts to bind and the real ones can go 60 degrees so later I will have to swap one on.
so much for this idea
PostPosted: Mon Dec 29, 2008 7:43 pm
that sucks. seems like something always screws a person up.
PostPosted: Tue Dec 30, 2008 6:25 pm
FIXED !!! No Bind took out section between our double u-joint shortened it and welded submerged in water quickly to not ruin the joints. relocated the heim joint to support. the idea behind this was I checked on the measurements of the flaming river double u joint and my center piece was longer than theirs so I figured why not try it!
PostPosted: Wed Dec 31, 2008 9:48 am
Looks good and and functional You could also shorten the steer column and soften up the u-joint angle to but looks like you got all the kinks out(pun intended)
PostPosted: Wed Jan 07, 2009 2:22 pm
ok here is the pic of it re-worked to take bind out steering feels better takes like 3 1/2 turns lock to lock I think maybe more? I will need to align it as close as I can than take it in have it done once its about ready to be on the street.
PostPosted: Wed Jan 07, 2009 4:44 pm
Looks good.
PostPosted: Wed Jan 07, 2009 7:14 pm
hey man I see your truck has coilovers, have you had a engine in it, if so what weight springs were you running I have qa1 3955 shocks with 7 in. 250 spring but it wont hold the truck up. thanks for any help
