It is currently Tue Jun 30, 2026 1:01 am
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: I got a Luv again
PostPosted: Wed Nov 12, 2008 7:47 pm
I got another arrival my Aerospace Components brake kit WOW! It is so beautiful I am afraid to scratch the parts or even put it on the truck haha! Quality workmanship! I am very happy can't wait to bolt them up when I am ready to.
I do however need to run a different master cylinder with at least 1" bore I seen a booster with master for about $150 but I am about tapped out cash. I may only be able to settle for a master cylinder???
PostPosted: Wed Nov 12, 2008 8:24 pm
They are a pretty awesome piece. When I got mine for my truck I had to get rid of my solid Centerline wheels and get some Weld Prostars so I could show of the brakes!! Aerospace has a master cylinder the is proportioned front and rear. So you don't need a proportioning valve. Can't remember for sure but I think it was around $100?? Have fun installing your new brakes. It is very easy.
PostPosted: Thu Nov 13, 2008 7:17 pm
test fitted the bearings and hub sure enough they fit!!!!
PostPosted: Thu Nov 13, 2008 7:48 pm
yeah for now I can only hide them behind these wheel disc hubcaps cause I can only afford to keep my white mojock wheels I have till later
hmmm a proportioned master cylinder sounds good! can you use a stock chevy luv booster assembly with this master cylinder? probably not cause its 7/8" piston
PostPosted: Thu Nov 13, 2008 8:12 pm
not sure about using the stock booster?? my truck doesn't have the stock firewall and nothing in the brake system is stock. my truck had 2 airheart master cylinders when i got it, so when i got the aerospace front brakes i decided to go with there master cylinder too. here is what it looks like.
http://www.aerospacecomponents.com/master_cylinders.htm
PostPosted: Sat Nov 15, 2008 12:14 am
oh boy lots of stuff recieved today!
21 circuit wiring harness
power window kit
and all my summit stuff
the summit full length headers will work thankfully good deal for $89
I really like the cable operated cut-out exhaust it will be slick
jamb tacks
3 point harness pair
edelbrock carb tuning kit
ignition switch
good looking inexpensive mirrors
Have 3 more things coming than that will be it for a while haha!
PostPosted: Mon Nov 17, 2008 9:51 pm
well ok I now have a garage I can use to work on my luv :) only I cannot keep it in there the whole time after I am done need to bring it back out
I am going to pull the engine but I need to build a cradle with some pneumatic tires something simple that I can store outside for a few.
that way I can do all my work on the front without fighting it being in my way
after that
I think I will go in this order
install rack steering
install/mod for QA1 coilovers and remove torsion bars after
install brakes
clean up motor mounts and any spots on front frame
modify firewall
work on the tilt front
shifter adjustment
there will be more for sure but I will concentrate on this for now!
PostPosted: Mon Nov 17, 2008 9:59 pm
good luck with your project. sounds like it will be fun doing the mods to your truck. should keep you busy for awhile!!
PostPosted: Sun Dec 14, 2008 1:17 am
ok so me and my dad talked as we stood by the luv and he has some good ideas to cut time but not corners so he has been helping me lately. I think the new parts I bought and the ideas of mine made him want to be involved haha! so cool Thanks Dad
tomorrow I am pulling the engine and transmission I got everything ready today just need to lift out tomorrow hopefully that goes well!
and I have found some bugs while disassembling
the carb kit is going to pay off as gasket was toast and probably needs to be jetted
my shifter is fine just the cable is binding for some reason hmmm?
couple spark plugs look funky
throttle cable was binding as well weird cause I was able to drive it on the freeway
more bugs to find :)
PostPosted: Sun Dec 14, 2008 7:39 pm
so we got the engine out we had the use of a forklift that made life easy
so once we got tranny and engine tarped for oregon weather we sprayed super clean on the front frame and began looking at it and we cut out the engine mounts they will not work with my rack and pinion
transmission mount will need work
PostPosted: Tue Dec 16, 2008 12:55 am
wow this is lame-o with out pictures huh! I really need to get some up here!
maybe I will just buy one for my xmas present haha!
PostPosted: Tue Dec 23, 2008 8:26 pm
so I will probably have the steering pretty close to done tomorrow
and will also be putting in the coilovers hopefully finish them up tomorrow as well so I will have some work there to keep me busy!
PostPosted: Fri Jan 02, 2009 2:19 am
will probably be working on the firewall tomorrow along with double checking my previous work on coilovers and steering its starting to look good!
PostPosted: Fri Jan 02, 2009 9:29 pm
wow! time really flies by when working on the truck (sawzall time) I cut out the middle section of the firewall went to town on it recessing it for the distributor clearance mainly and the fact it looked ugly being beat with a 5lb sledge im sure was used. well I brought out the torch anvil and small little ball peen hammer and formed it.
took forever but will look nice. just need to finish tomorrow welding it in I ll try to have some pics of it up for you all!
PostPosted: Wed Jan 07, 2009 2:34 pm
ok well I have put a tiny dent in the stuff to be done list.
rack & pinion
coil over suspension (torsions gone)
firewall recessed (ball and peen, anvil and torch)
it may not look purty right now I have not done the grinding and beautifications :econfused if thats a word I will do that all near the end of the work on front end
the firewall will require a little bondo and there is some welding left on it to make it look smooth and keep it structural.
next is the tilt front
I want to get it done cause I thought I would have had it done about two months ago oops!
anyways I have 90% of the parts I just need some 5/16" round stock for fender bracing
PostPosted: Tue Apr 07, 2009 12:53 pm
ok so with the layoff i took a break from the truck but still have and I will begin working on this weekend or next. good weather is kicking in so..... but I abandoned the full tilt on the truck for now will later do that. I have some work ahead of me mainly cleaning up the frame work doing some more welding and such. than some body work I bought some dura glass woo hoo!
I think i can fit the aerospace brakes with a 15in wheel if the offset is right I mean they are 12" brakes but I will just have to see???? also going to use the stock master cylinder see how it works its a 7/8 bore it says 1" recommended but if i dont feel its satisfactory than i will get the 1" w booster
so yeah the list i have seems easy but im sure its gonna have some bumps
I have got most of the hard work completed though so :)
well wish me luck
I ll get on the college comp and get some more pics soon
oh and if anyone see something they can help me with much appreciated
alright fellas
late
Users browsing this forum: Baidu [Spider] and 38 guests
