It is currently Mon Jun 08, 2026 2:06 pm
PostPosted: Thu Dec 11, 2008 11:55 am
I've got the weber on the offy and exhaust headers on my 79 4x4 mikado and love them to death. Sometimes when I turn it off the engine it kinda keeps going and doesn't shut off instantly. I don't know what you call it, but it doesn't seem like it should do that. Let me know what you guys think thanks.
PostPosted: Thu Dec 11, 2008 1:24 pm
does it cough or sputter? or just stay runnin when you turn key off
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Thu Dec 11, 2008 7:12 pm
Sounds like it is dieseling. Maybe turn the idle down a little, check the timing. Mine will now and then, but I found that if I let it idle for about 30 seconds, then shut it off it won't diesel.
PostPosted: Thu Dec 11, 2008 8:30 pm
When mine did that many moons ago, the timing was off.
PostPosted: Thu Dec 11, 2008 9:32 pm
I fixed my dieseling by adjusting the idle, both the idle speed and mixture. I think that mixture may be more important--I think some idle speeds are spec'd at 800 or 850 RPM, which seems high to me. I set idle by getting it as lean as possible-just enough to keep it running. The method in the shop manual or Chilton doesn't serve me very well either; the idle mixture screw, at least on my carb, doesn't do much for about 10 turns. That's too far out.
PostPosted: Sat Dec 13, 2008 3:10 am
Thanks guys it's been a couple days since I could check this post. I'll take a look at the idle, I've got it kinda high at about 1000 just cuz I like it there. But you guys are probably right about the timing. I don't have the vacumn advance hooked up and the mechanic I talked to said I should probable advance it a little bit. But at the end of this month or next month I'm going to go with the electronic distributor and stuff. I'm just glad this isn't indicative of a larger problem. I'll definately check it out thanks guys!
PostPosted: Sat Dec 13, 2008 9:31 am
This is not a fix, but a way to deal with it untill you fix it.
If it's a manual transmission, you could just put one foot on the brake and the other letting out the clutch (in gear) a little while you shut the eng. off. That will stop the eng. as soon as you turn the key.
Users browsing this forum: Bing [Bot] and 29 guests
