It is currently Mon Jun 08, 2026 2:06 pm
 Post subject: alternator questions???
PostPosted: Wed Dec 10, 2008 5:24 pm
kwik questions... if my truck is on and I remove the positive wire from the battery. should the truck stay on? if it doesn't, what can the problem be? just got the alternator checked and it's good.
PostPosted: Wed Dec 10, 2008 5:55 pm
That is a good question. I know on military HMMWVs if you take the pos away it will die but not real sure on the civilian trucks.
Some times I amaze even myself!!!!
PostPosted: Wed Dec 10, 2008 7:24 pm
I would bet a wire issue some where in the harness. When you say it is charging, are you checking it at the battery with the battery hooked up?
PostPosted: Wed Dec 10, 2008 9:01 pm
I got the alternator checked at autozone... I'm just removing the positve wire from the battery and it turns off immediately. I've had this issue for a while now and trying to fix it. the gen light is on in the dash too.
PostPosted: Wed Dec 10, 2008 9:58 pm
Pulling the battery wire off the battery while it is running IS NOT a good way to test as you can get a voltage spike in the alt. and kill it or worse although rare the alt can short out the diodes and now you will have 120-140 ac volts in your hand.
The best way to check is with a volt meter.
Users browsing this forum: Bing [Bot] and 29 guests
