It is currently Tue May 26, 2026 8:39 am
PostPosted: Sun Dec 07, 2008 8:01 pm
i need alot of room prolly like a 6 inch cowl! i want to get a bolt on scoop ill weld it on and cut out bottom! I just dont know where to get one ? anyone running one or haqve any pics! :?:
6.0l ls1 swap th350
PostPosted: Sun Dec 07, 2008 9:39 pm
www.UP22.com
PostPosted: Mon Dec 08, 2008 11:20 am
yea i seen those thats way off budget for my truck ill just cut a hole in the hood!lol i figured they had a universal 6 inch cowl that i could modify to fit my hood there has to be someone on here that has done this!!! :roll:
6.0l ls1 swap th350
PostPosted: Mon Dec 08, 2008 1:53 pm
I can't think of who it is but there is a cut to fit steel cal scoop out there that you epoxy glue on then finish the body work.Oh and when you put it on it better be right as you will tear the sheet metal before you get the glue to let go.
PostPosted: Mon Dec 08, 2008 3:12 pm
thats what im looking for! I wonder who is running it on here???
Seems like no one gets on here anymore :|
guess ill check around :roll:
6.0l ls1 swap th350
PostPosted: Tue Dec 09, 2008 7:35 am
I am going to go though some of my magazines and see if i can find the glue on one as i forgot that a good friend of mine put one on his 57 chevy and it looked good like it was made that way.
PostPosted: Tue Dec 09, 2008 8:45 pm
:roll:
PostPosted: Thu Dec 11, 2008 2:23 pm
I just looked on ebay motors.... over 2000 listed under hood scoops .
Just check it out... good deals and rip offs I am sure.
