It is currently Mon May 25, 2026 4:23 am
Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Tue Nov 11, 2008 2:45 pm
I dont have a good close up of the mounts but i got them from s10v8.com ls1 conversion mounts to 2.8l frame mounts i just welded and bolted the 2.8 frame mounts directly to the original luv mount on frame
6.0l ls1 swap th350
PostPosted: Tue Nov 11, 2008 2:47 pm
just sat cab on today
6.0l ls1 swap th350
PostPosted: Sun Nov 16, 2008 9:37 pm
some more
6.0l ls1 swap th350
PostPosted: Sun Nov 16, 2008 9:39 pm
need a front bumper or front valance very bad! :|
6.0l ls1 swap th350
PostPosted: Sun Dec 14, 2008 8:57 pm
hey brandon what did you do about torsion bars just cut them and thread them to get a bolt on the back side of lower control arm?
getting ready to put my coilovers on
thanks in advance
PostPosted: Mon Dec 15, 2008 9:59 pm
just cut them off they wont come out i figured this out someway lol havent messed with it in a while but im pretty sure they wont come out
6.0l ls1 swap th350
PostPosted: Tue Dec 16, 2008 12:50 am
ok cool thanks! I ll look it over I think the bolt on the front side does suck it in so I bet your right :P
PostPosted: Tue Dec 16, 2008 9:06 pm
yea i think that was the reason :wink:
6.0l ls1 swap th350
PostPosted: Wed Dec 17, 2008 5:13 am
are yall taking about where the front of the bar goes inthe a-frame? should pull out.
when i got my step side the drivers side was cut off at the front i couldn't get it to come out either, so i started soaking it in wd-40 and tapping on it finally it came out but it had a suction on it due to the rust that made it a tight fit...i would pull alittle and it would suck back in a little...i used a set of channel locks and a screwdriver,i would pull it out and use the screw drive to hold it in place so i could get another bite on it with the channel locks.
PostPosted: Wed Dec 17, 2008 10:27 am
i havent lookeed at mine but i think it will only come out the back and there is a nut on the front. and there no room for it to move forward. :?:
6.0l ls1 swap th350
PostPosted: Wed Dec 17, 2008 10:35 am
Go to my project thread and look at the 2nd and 8th picture.... is that the area your talking about?
PostPosted: Wed Dec 17, 2008 10:36 am
i did try to knock mine out with a sledge hammer with no weight on it and it wouldnt budge if u wanted to be safe u could take a big nut or washer and put it around the back side and weld it so it couldnt move. the front side is locked
there a pic on the first page where u can see it
6.0l ls1 swap th350
PostPosted: Wed Dec 17, 2008 10:40 am
yea thats it with the nut on the front side and nothing on the back. i might put the nut or washer on and weld it i dont ant to fight getting it out.
6.0l ls1 swap th350
PostPosted: Wed Dec 17, 2008 10:49 am
i see the stub sticking out and it should pull out, what i did was get a bite with pliers on the stub end,tapped the sides and pulled at the same time, it took some soaking in WD-40 but it came out eventually.with what you have you could get some vise grips and lock them down on the stub and tap on them but soak the hell out of it first for a couple of days( spray it everyday ) if you haven't done that already.
PostPosted: Wed Dec 17, 2008 12:55 pm
what did you put in place of it after you pulled it CT's Luv? I was thinking like what brandon said have something on the back side but not tight up against the lower control arm might cause a bind. Glad I mentioned something about that to ya brandon that would suck for it to slip out which would be hard but still just for security.
I am following your build as well its coming along! I am going to have to fabricate the mounts for my qa 1's (like you have done) it has the eye mount. I would rather just make it than buying the stud conversion.
PostPosted: Wed Dec 17, 2008 1:00 pm
i was just replacing the T-bar not going to coil over, i would silicon a plastic pipe plug in if you could.
PostPosted: Wed Dec 17, 2008 5:21 pm
ok after looking at it seems the reason i did nothing is because the only way the torsion bar to come out is to pull the nut off the front and pull to rear. It cannot go forward because of its size....actual bar is bigger then the end where it bolts on. so there is no need to do anything if it did randomly your steering would hit it. but if your real worried about it then do somethin about it :wink:
6.0l ls1 swap th350
PostPosted: Wed Dec 17, 2008 8:35 pm
Gosh ya know I pulled torsion bars out of a luv before just never looked closely. Its been cold outside haven't done much since the engine pull cause after that it started. but it tapers down oh ok sorry I didnt look so close oops :oops:
Thanks
PostPosted: Thu Dec 18, 2008 12:47 pm
gastank mounted aluminum came out of a boat!
6.0l ls1 swap th350
PostPosted: Thu Dec 18, 2008 12:53 pm
took heads off to get redone and patriot dual gold valve springs put in
6.0l ls1 swap th350
Users browsing this forum: Bing [Bot] and 20 guests
