It is currently Tue May 26, 2026 3:31 am
 Post subject: Toyota brake rotors
PostPosted: Sun Nov 09, 2008 3:56 pm
I have some weird home made adapters for the 5 lug rotors on my LUV. They are safe and work well but I would like the tires to suck in some. I don't really want the aerospace kit as my truck is not ment to race. Can someone that has the rotor converson from stock LUV to the Toyota upgrade take a measurement for me. I would like the measurement from the outside of the rotor face to the outside of the caliper hold down. I am trying to suck in my front rims/tires some.
 Post subject: Re: Toyota brake rotors
PostPosted: Sun Nov 09, 2008 4:13 pm
Aerospace does also make a street version disc brake setup
PostPosted: Sun Nov 09, 2008 5:47 pm
yeah the aerospace street kit is around $720 spendy but worth it 12" brakes
I ll have some pics up soon hopefully. They have not arrived yet but should this week
PostPosted: Sun Nov 09, 2008 6:15 pm
you are right, aerospace kit is spendy but worth it. i bought the drag race kit for my truck. you can't put a price on one's life!!!1
PostPosted: Sun Nov 09, 2008 6:48 pm
:signhijacked :evil:
PostPosted: Sun Nov 09, 2008 8:09 pm
It's all good Tilted. See, I have a allowance for my toys and the brakes I have now are plenty good as I don't race the truck. So basically the more I spend on my LUV this winter the less I have for my airplane, thats why I was thinking about the Toyota deal. This is only a cosmetic change, the function is fine.
PostPosted: Sun Nov 09, 2008 8:43 pm
In Hotrod80's sticky on this subject I found the following info...
knocked out the old studs and bought 1/2-20 tuds to replace the metric studs . I also had my hubs machined on the wheel face to reduce the wheel base difference from the factory Luv set up . The best I can tell the toyota rotor set up is approx 1" wider than the stock Luv . I had almost 1/4" machine off . This is a judgement call on your part . I did mine , you will have to decide for your self if you feel safe removing material from the hub or not .
PostPosted: Sun Nov 09, 2008 11:15 pm
Why do you want Toyota brakes on your airplane??
Wait, did I miss something here? :lol:
PostPosted: Sun Nov 09, 2008 11:57 pm
:imwifstupid
PostPosted: Mon Nov 10, 2008 12:10 am
sorry bout the hijack
PostPosted: Mon Nov 10, 2008 10:18 am
Cant you fix it with wheel offset???
Toyota 5 lug is the same as fords 5x4.5" or whatever, but why not use Toyota rims off a FWD on the front to bring the tyre in. The large toyotas like the Camry and Rav use a nice dished in offset. And you can buy aftermarket rims for them. Im sure you could get them in the same style as the rims you could buy for a Ford. Toyota offset on the front and Ford offset on the back.
Get your self a spare wheel that carries and offset that will work on both ends.
Just a thought.
bob.
PostPosted: Mon Nov 10, 2008 11:05 am
My rims are made for either Ford or Chevy bolt patterns. They are 4" wide so I cant get any more narrow.
PostPosted: Mon Nov 10, 2008 4:17 pm
sorry about the hijack too :oops:
PostPosted: Mon Nov 10, 2008 4:49 pm
No problem fellas.
