It is currently Fri Apr 03, 2026 7:16 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Jul 10, 2008 8:27 pm
Just buy a Subaru Brat sticker and put some seats in the back.
PostPosted: Fri Jul 11, 2008 7:16 am
LOL the kids would love that!!! ANd it will drown out them fighting! That might be an an option :roll: !
PostPosted: Fri Jul 11, 2008 10:05 am
This is the master cylider that was recomended and I found this one used with th booster on EBAY, does anyone think it would be a good idea to use the complete unit booster and master cylinder. I was thinking this since it would have came from truck that already had 4 wheel disk brakes. Any ideas
http://cgi.ebay.com/ebaymotors/79-89-DODGE-PICKUP-MASTER-CYLINDER-BOOSTER-BRAKE-VAN_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ33566QQihZ024QQitemZ370041831481QQrdZ1QQsspagenameZWD1V#ebayphotohosting
PostPosted: Fri Jul 11, 2008 11:08 am
Booster too. WOW.
I wonder if you could put a pressure regulator on it to run drum brakes in the rear axle.
PostPosted: Fri Jul 11, 2008 11:16 am
I found a new unit like that, booster and all for about $ 100.00 at advanced auto parts
PostPosted: Thu Oct 09, 2008 7:32 am
OK finally got my Master Cylinder http://www.dragstuff.com/techarticles/RacingMasterCylPN.html but I am not sure what size brake lines to run.I am using a brake booster also. I want to replace all my lines.
Here is the complete setup:
Rear Calipers are Front S10 calipers Using bolt-on brackets from http://www.kore3.com/products.php?cat=16
11" rotors on rear
Front Calipers are twin piston from a Silverado
12" rotors on front
Any advice would be great
PostPosted: Thu Oct 09, 2008 7:51 am
What part number is the master? If it is the one you asked me about in another thread it is a 3/8-24 inverted flare. I could not find a master using the dragstuff numbers that had the 3/8 size and the adpater part numbers were incorrect. The hardline should be 3/16 tube. The stock LUV hardlines are 3/16 tube, but the nut size is 10mm. I got tired of waiting on my adapters and got a couple of extra hardlines (the short ones are cheap) and used the 3/8 inverted flare ends off those on the LUV lines using a double flaring tool. The Luv lines to the rear should be the same ends as the ends of the rubber lines for the S10. Not the part that goes in the caliper, but the other end. Not sure on the Silverado..
PostPosted: Thu Oct 09, 2008 8:05 am
This is the parts I have ordered:
Part # 131860 Cardone Master Cylinder
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=A1C&MfrPartNumber=131860&PartType=230&PTSet=A
Part # 5473770 Cardone Brake Booster
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=A1C&MfrPartNumber=5473770&PartType=250&PTSet=A
PostPosted: Thu Oct 09, 2008 8:10 am
Those links don't work. The site won't allow you to look without joining, so...
PostPosted: Thu Oct 09, 2008 8:16 am
Sorry about that:
Try this one
PostPosted: Thu Oct 09, 2008 8:29 am
Here is the link to Napa's site
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=430&CatId=3&SubCatId=3
Here is the info for the port sizes:
Line Thread Size:(1) 9/16" - 20 & (1) 1/2 - 20
Brake Cylinder Bore Size:1 1/8"
# of Line Ports:2
are these the fitting sizes?
PostPosted: Thu Oct 09, 2008 8:38 am
Yeah, those are the thread sizes. You will most likely have to either order or have a truck shop make you lines with that size end on one end or try to order an adapter to go to the size you need. I went to several local places when I got the master off the Dragstuff link, and it came with those sizes. I couldn't find anything local and ordered the master with the 3/8-24 ports as that's a standard size. Just curious... Why are you wanting to use a booster?
PostPosted: Thu Oct 09, 2008 9:16 am
Thanks for the Info
I am using the booster because I am making this a daily V8 driver and I thought I would need it.
PostPosted: Thu Nov 06, 2008 6:16 pm
interesting topic! I am getting the aerospace disc kit up front I am going to swap the master cylinder will I have to get a new booster as well? can I use the stock one? thanks for any answers.
PostPosted: Thu Nov 06, 2008 7:44 pm
I run the stock booster with no problems. I have re-drilled front brakes and rear drums (not too sure of the dia.but it is a 9"rear end) with 2 1/2" wide and my truck stops great. I still would like to upgrade to the Aerospace front brakes.
PostPosted: Fri Mar 20, 2009 10:44 pm
bama since this thread was several months ago can I see some pics of the booster/master installed in firewall? Also any of you know what size this hose would be on connection to hard line? 3/8?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=
PostPosted: Sat Mar 21, 2009 6:51 am
I will try to get pics soon. The truck has been slow in getting done. But the master cylinder and brake booster are a 9" chevy disc/disc unit from a 90's camaro I think, it was from a frieds parts pile, I will rtry to find out.
The hard line would be a standard full size chevy or an s10 brake line would work too
PostPosted: Sat Mar 21, 2009 11:49 am
After installing several disc/disc systems i have found and learned that using the front calipers off any thing can and will usually create more problems then its worth.Aside from the obvious no read park brake it is real difficult to control the brake bias due to the front caipers have such a massive amount of clamping force (very large piston) the cheapest and best for the money that i have found is the caliper setup off the back of the mid 80's Toros and variants(front wheel drive) as these are the same as the mid 80's Camaro/Firebird but at a fraction of the price even the mounting bracket is the same but i never liked the heavy rotors(same as front) so i would get the rotors off mid 70's Toros then cut them down to size( 1.120 to .990) and the last setup i got was 40 bucks.
It's up to you as it is your rig, i am just stating my experience in this matter also it is the setup that is on my truck in my avatar. There is more info but i guess i ranted enough.
PostPosted: Sun Mar 22, 2009 6:02 am
Thanks for the info, rant all you want, if it will save a headache then definitly go right ahead. For now I am running the stock front disk with s10 front calipers on the back. No parking brake but I am trying to figure that out ( using the S10 caliper b/c they are free). Also are running 5 lug or 6 lug?
PostPosted: Sun Mar 22, 2009 10:07 am
Adapting a mid 70's/early 80's vette set up would be cool. They have a mini drum setup inside the rotor...
