It is currently Sat May 09, 2026 11:57 am
 Post subject: g200 engine help please
PostPosted: Sun Oct 12, 2008 12:29 am
I'm putting a g200 engine in my luv but it won't mount up to the motor mounts in the frame. what should I do.
PostPosted: Sun Oct 12, 2008 9:48 am
HUH, its a direct replacement for the late model G180 used in LUV's from 76 on. Is your truck a 75 or older?
PostPosted: Sun Oct 12, 2008 12:43 pm
yeah 79 4x4
PostPosted: Sun Oct 12, 2008 1:26 pm
If you didn't swap the oil pan, it is most likely the problem...
PostPosted: Thu Oct 23, 2008 12:56 am
Are you using the block mounts that the G200 came with? If so put on the G180 luv mounts and it should bolt right in kinda sounds like you have mounts for a isuzu car or something.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Oct 23, 2008 8:35 am
Yep, its gotta be one or both of those. Need the 4x4 oil pan and need the mounts off the LUV G180 block if using a G200 that was not from a truck. The Impulse mounts are very different.
PostPosted: Thu Oct 23, 2008 2:41 pm
I don't want to high jack this thread just throw in a side question sort of on topic. OK a 2WD oil pan will not work on a 4WD. But will a 4WD oil pan work on a 2WD?
PostPosted: Thu Oct 30, 2008 3:01 pm
It should I think. if you use a 2wd pan on a 4wd you will shear the gasket and leak all of your oil out in 1/2 a mile. Ask me how I know!
PostPosted: Fri Nov 07, 2008 4:12 pm
Swap Specialist Mod
4wd pan will work in a 2wd. i put a g180 from an 81 4x4 in my luv back in the day and the pan fit fine.
