It is currently Tue Dec 16, 2025 3:36 am
PostPosted: Wed Sep 24, 2008 11:56 am
Bought a longblock and replaced the 4.3L in the 86 GMC 4x4. Decided against using the stock intake manifold & Rochester 4bbl carb. Instead used Edelbrock intake 2111 and carb 1404. Installed no emmissions on new engine. Got the engine to fire up and run but will not idle. Have to tap throttle in order to keep engine running. Has manual choke, if choke pulled will run at 2000 RPM give or take...
Could the fuel pressure be causing this problem? Is there any weird configuration on the fuel saddle fuel tanks that could be causing this problem?
Can drive the truck, at 2500 RPM and up seems to run OK. Need to idle so I can set the timing though.
Thanks for any help on this issue.
75 Luv 350/TH350 (Project in progress)
PostPosted: Wed Sep 24, 2008 12:34 pm
is there an adjust screw on the carb for idle??
PostPosted: Wed Sep 24, 2008 4:14 pm
may have a vacuum leak. you can spray carb cleaner where the intake bolts to the heads and also around the base of the carb. but be carefull and it could catch fire!!
PostPosted: Wed Sep 24, 2008 4:47 pm
when doing this it will idle high if a leak, correct?
PostPosted: Wed Sep 24, 2008 4:51 pm
yes
PostPosted: Sat Sep 27, 2008 10:18 am
Thanks for the help wildluvracing1974... I'm going to check it out this weekend... Hope I don't set it on fire.
PostPosted: Wed Oct 01, 2008 10:35 am
Removed intake manifold and add RTV silicone gasket maker to the gasket to insure a good seal. Still won't idle. Actually won't hold consistant RPM without moving throttle. Sometimes when trying to get it to run at low RPM it will surge up to 2000 RPM or more for no reason. Work in progress... :?:
PostPosted: Wed Oct 01, 2008 12:30 pm
I'm not a fan of those Carters, er....Edelbrock carbs....
PostPosted: Wed Oct 01, 2008 6:40 pm
yep my bad!!! :( could be a carb problem.
PostPosted: Wed Oct 08, 2008 10:43 am
Thx WildLuvRacing1974... You were right, it did have a vacuum leak. Runs great now! :D
PostPosted: Wed Oct 08, 2008 6:18 pm
No problem. Glad you got it running good. :D
