It is currently Wed Apr 01, 2026 10:14 am
PostPosted: Sun Aug 17, 2008 3:36 am
hey guys this might sound a little random but i cant seem to work out how to get my stock steering wheel off without damaging the factory center part of the wheel... is there a little trick i'm missing in this process...??? i just want to move it so it is straight to steer again... wow i sound so stupid but this is the only thig i hav not beeen able to nut out.. a quick help would be much appreciated, thanks heaps guys all the way from australia. :?: :?: :?: :?
PostPosted: Sun Aug 17, 2008 3:59 am
Australian LUV Guru
Push and twist :wink:
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Mon Aug 18, 2008 1:47 am
if you still need to get the wheel off take the nut off spray some wd-40 on your shaft :lol: ok stop it you guys then put the nut back on not to far leave a bit lose then hit that bad boy with a big hammer as your buddy pulles on it but be careful not to screw up the shaft after it pop lose take the nut off and you got it off :oops:
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Wed Aug 20, 2008 1:06 pm
Yea like budbuondo said put the nut back on loosely or youll be an idiot like me. I was in a hurry and removed the nut and pulled on the steering wheel really really hard. It finally came off but i pretty much hit myself in the face with the wheel. :oops:
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Aug 20, 2008 5:25 pm
OUCH!! Sounds like something I would do!!!
PostPosted: Wed Aug 20, 2008 7:46 pm
Dan, don't feel too bad. I cracked two ribs in high school doing exactly the same thing. :oops: :smt091 :|
I won't ever forget to leave that nut on again though...
PostPosted: Wed Aug 20, 2008 9:34 pm
It's like a right of passege to a gear head, don't ask me how I know.
PostPosted: Thu Aug 21, 2008 12:00 am
Yep.
Wheel pullers are Good!!! :oops:
PostPosted: Thu Aug 21, 2008 11:25 am
A brass punch works good. I have used a block of wood too, it works ok.... Wear safety glasses. Don't want to have a splinter removed from your eve.
PostPosted: Thu Aug 21, 2008 7:04 pm
One of the best tools I ever bought from Harbor Freight, steering wheel puller, about $3.00! 8)
PostPosted: Sat Aug 23, 2008 11:19 pm
thanks guys... the wheel its self came off relitivly easy it was just the plastic cover on the horn of the stock luv wheel i could not work out.. thank heaps...
