It is currently Sat Dec 13, 2025 5:12 pm
Post new topic Reply to topic  [ 364 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18, 19  Next
 Post subject: Re: motors in! (pic)
PostPosted: Wed Aug 06, 2008 4:12 am
LOL... sound good hotrod hope the new comb works good for ya.
PostPosted: Wed Aug 06, 2008 4:40 am
Ct glad your laughin cause my combo will have so much done to it I don't know what it will do .
Farmer , it is still tagged and inspected . I just got a little to serious with it . Kinda wish i'd stayed @11.50's
Terry , thanks for the heads up . Hope I don't have to make driveshaft changes . i need to get it together so I can get the rear bars adjusted .
PostPosted: Wed Aug 06, 2008 4:55 am
If you're going from a th350 to the 'glide, the shaft should be the same...
PostPosted: Wed Aug 06, 2008 5:19 am
Thanks , TH350 & the shortblock out of the Luv are going into the 67' .
PostPosted: Tue Aug 12, 2008 1:24 pm
O.K. still on the fence about axle shafts . Looking at going 33 splines and new spool or staying 31 . Axles are the same cost . I also got with glassman Chad yesterday while picking up CTluv's old grey truck 8) , and he said he's gonna cut me a glass rear window to go around the bars and polish all the edges , then have it sent off to temper . This is doable , but nobody goes the extra mile to do it . Glide sould be in by thursday . Hoping for some test-n-tune time friday and maybe sunday . Also going long tube headers , which will force me to run a fuel cell in the bed :roll: . 3" exhaust with race muffs dumped in front of the rear axle . I hope this motor lives until the new one gets done .
PostPosted: Tue Aug 12, 2008 7:39 pm
Your axle twist problem will diminish greatly with the 33 spline set up. If I remember correctly, the warranty on a set of 31's is like one or two years, the 33's are lifetime. Mine are 33's, and I haven't twisted one yet...
PostPosted: Tue Aug 12, 2008 7:45 pm
Thanks for the info . What brand are your axles ? Ima call tommorow with the specs and probably just go ahead and do the 33's . If you haven't had any problems , then my little combo and drag radials won't hurt them .
PostPosted: Tue Aug 12, 2008 8:05 pm
I have Strange axles...
PostPosted: Tue Aug 12, 2008 8:31 pm
Moser axel has a great rep out here.
PostPosted: Tue Aug 12, 2008 8:43 pm
I've used Moser before, nothing wrong with them at all. The Strange were in the truck when I got it...
PostPosted: Tue Aug 12, 2008 9:12 pm
prolly gonna go with Moser 33's set up ready to bolt in with there spool . Just set the back lash and install the axles . It is like $650 delivered with studs, sealed bearing installed , retainer plates , prolly have the spool bearings installed also , as I don't even have work bench or a vise much less a press . :roll:
PostPosted: Tue Aug 12, 2008 9:38 pm
BFH... :P
PostPosted: Tue Aug 12, 2008 11:14 pm
33 spline mosers and have had no problems yet.....
PostPosted: Wed Aug 13, 2008 3:52 am
31 spline strange no problems.
PostPosted: Wed Aug 13, 2008 12:51 pm
33 spline Moser package ordered . $648.84 to the door . Wife gave me a 1K allowance , but ima be doin dishes for a long time if i don't win again soon . i'll order the shifter and mufflers tonight and install the headers while I have the tranny out tommorow . Guess I should take some pics of all this . Oh , and looks like the carrier bearing will git the old block o' wood , BFH install .
PostPosted: Mon Aug 25, 2008 9:31 pm
O.K. got all this done bout 1 am saturday morning . Slept till 11:30 sat and couldn't stand it . Loaded up and went to Houston raceway park (1/4 mile ) for test-n-tune between rounds of the bracket race deal ( good track prep) . It was hot track temp was like 155* ambient was like 100* sun was brutal . First pass was slow , as i loaded an empty N20 bottle in the truck . I let it cool and loaded a full bottle in it and made a second pass . This time it left and i mean left . 1.50 60' 12" to 14" wheelie and straight as an arrow clicking the 660 beams @ 6.55 @105 . IM ON A PASS BABY ! The thing is clean , no pop or bang . I shift to second still clean , buzz through the traps 2 7200 with passenger side of the hood about 1" high ( broken spot weld ) 10.36 @ 127 ! My fastest pass ever . Got back to the house about 3:00 thinking about Clobberthon 50 starting a@ 6:00 pm only to find out it was rained out , but the track (Houston motorsports park 1/8 mile ) was still open for test-n-tune . Got a call from the guy who heads up the class im running now about a jack pot race everybody was gonna do . Back on the road . Got there about 7 un loaded and ran a 6.45 off the trailer . Went 2 rounds and decided to change plugs , as i was to run #1 quailfier next round ( I was #2 quailfier ) . This was a mistake on my part . I changed to a different plug and went 1 range cooler . It killed the plugs at the 1/2 shift and went through at 6.90 . I had this guy by a tenth at the 60' mark and i don't think he could have gotten around me . This thing dead hooked on drag radials all day long . Anyway I got a couple of crappy pics to go with the update . I am still sore and have a header gasket to replace .
PostPosted: Tue Aug 26, 2008 1:48 am
Glad to hear the truck is running good. Congrads on the #2 qualifier.
PostPosted: Tue Aug 26, 2008 3:49 am
i never got my phone call hotrod, me and the little one were ready to come out and watch.
PostPosted: Thu Aug 28, 2008 4:00 pm
Sounds like you had a blast! Great pics!!!
PostPosted: Thu Aug 28, 2008 9:07 pm
HOOOOOLLLLYYY COW! I saw your avatar and had a mega flashback . Good to hear from you and check in more often .
