It is currently Fri Mar 20, 2026 3:11 pm
PostPosted: Tue Apr 08, 2008 12:19 am
just wondering came across one thought it might be cool!
6.0l ls1 swap th350
PostPosted: Tue Apr 08, 2008 7:36 pm
Swap Specialist Mod
i dont think that anyones ever done a LS series swap into a luv.
PostPosted: Tue Apr 08, 2008 8:26 pm
hmmmm. interesting
6.0l ls1 swap th350
PostPosted: Tue Apr 08, 2008 9:04 pm
i almost just bought an LS1 to put in mine but didnt wanna do all the computer stuff and all the extra wiring so then i jus got a 305 sbc
PostPosted: Tue Apr 08, 2008 9:10 pm
Swap Specialist Mod
well it really all depends on how much money you wanna spend. if you can get the engine/trans and all the controllers for a reasonable price, then all it would be is getting the engine mounted, and getting it wired.
if you cant get the harness for the motor, then msd sells a controler that will run the motor, but then youll have to figure out a trans.
check out http://www.ls1tech.com for LS series info.
PostPosted: Mon Apr 21, 2008 6:51 pm
http://www.edelbrock.com/automotive_new/mc/manifolds/chevy/victor-ls1.shtml
PostPosted: Mon Apr 21, 2008 7:54 pm
will this work on a 5.3l i can get the whole motor with wiring except ecm?
6.0l ls1 swap th350
PostPosted: Mon Apr 21, 2008 8:49 pm
Sounds like it should. Looks like you need this part too.
"Timing Control Module made by MSDĀ® which works with OE sensors to fire the coil-on-plug ignition system and offers a choice of six timing curves. A special throttle and trans bracket that works with 700R-4, 200R-4 and Turbo 350 transmissions is included, making the LS1 engine an easy retro-fit into any muscle car, street rod or marine application. "
I am not sure if you can put a distributor in it.
PostPosted: Mon Apr 21, 2008 9:05 pm
dnt know either gonna look around on internet about it! thanks for the link
6.0l ls1 swap th350
PostPosted: Thu Apr 24, 2008 6:11 pm
well i stepped up to the plate guys got me a 6.0l outta a 2002 yukon and im gonna carburate it. Goin to pick it up tommorrow Its gonna be an awesome project!
6.0l ls1 swap th350
PostPosted: Sun Apr 27, 2008 12:23 pm
Keep us posted. Take lots of pictures and notes!!!!
Good luck.
PostPosted: Sun Apr 27, 2008 3:04 pm
i just started another post. go check it ill be posting updates on it.
6.0l ls1 swap th350
PostPosted: Tue Aug 05, 2008 3:21 pm
viewtopic.php?f=6&t=16935
6.0l ls1 swap th350
