It is currently Mon Feb 02, 2026 4:45 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 Post subject: tires
PostPosted: Wed Jul 30, 2008 8:12 pm
will a 10.5 slick fit under a 79 luv with out cuttin fender wells and etc.?
ME LUV IT LONG TIME!!!
 Post subject: Re: tires
PostPosted: Wed Jul 30, 2008 8:14 pm
With the proper backspacing...
PostPosted: Wed Jul 30, 2008 8:17 pm
what backspacing do i need to go with.. 4.5??
PostPosted: Wed Jul 30, 2008 8:35 pm
It's been so long since I ran that scrawny size. :lol: Hotrod80 or CT's LUV should be along later and give the correct size. It will depend on whether you are running a stock width rear as to whether it will work though...
PostPosted: Wed Jul 30, 2008 8:55 pm
i wanna say it has a shortened 10 bolt in it i dunno how much its been shortened or anything i bought the truck like that.. i''m just now gettin into this whole luv truck dragster thing so i'm gonna have a bunch of question as i go along.. its already set up for a v8 and i've completely gutted inside of cab and cut out all the inner fenders up front and got it sanded down and in primer just waitin for some more money so i can do some more.. another question.. where can i get a weld in rollcage designed for these trucks that require no bending(pre bent).. that way all i gotta to is stick it in weld it and be done or is that not gonna be possible?
PostPosted: Wed Jul 30, 2008 8:56 pm
Again, wait for HotRod 80 for answers.
PostPosted: Wed Jul 30, 2008 8:59 pm
Some of your ? can be answered in this thread... viewtopic.php?f=4&t=11231
PostPosted: Thu Jul 31, 2008 12:26 pm
with a 10.5 and 4.5 inch of backspacing i had to use a 1/4 inch spacer on my pro stars but with a 4 inch backspacing it was ok , until i turned onto the return road and it would rub a little bit due to low presure and tire flex. i have a 9 inch tire and its a really good fit.
PostPosted: Thu Jul 31, 2008 12:41 pm
ok here is a picture with a 10.5 left side and a 9 on the right, this is a 15x8 with 4.5 inch back spacing.....notice the gap from frame to tire.
this is a 15x8 rim with 4 inch backspacing wheel and the tire tread was even with the outside of the bed, i never had it hit the tire at all
PostPosted: Thu Jul 31, 2008 4:05 pm
the luv i have already had the adapter for a 5x4.5 bolt pattern i'm guessin the adapter is 1/4 inch i'm not sure i havent really looked at it but i know its on there... i would imagine its probaably wider then 1/4 inch... i plan on running 15x4's on the front i know those will fit for sure but i was thinking about running a 15x10 rim on back with a 10.5 slick plus the adapter of course.. not to sure if it'll fit i'm not really wantin to cut the fenders move the frame and etc.. nor do i want the tires to stick out of the fender either..
PostPosted: Thu Jul 31, 2008 4:30 pm
Yup , CT's correct 4.25 " back space . You may also have to smooth some frame issues with a grinder .
PostPosted: Thu Jul 31, 2008 4:33 pm
do with 4.25 inches a backspace a 10 inch rim and a 10.5 inch slick i'll be alright?
PostPosted: Thu Jul 31, 2008 4:52 pm
4.25 " is the most backspace that will fit in a stock set up . I also run 15x8 4.50 with a .25 spacer . A 10" rim will just move the tire out further . Just to make sure we are talking about a true 10.5 tire , not a 10.5W . It is pretty close as you can see by the pictures .
PostPosted: Thu Jul 31, 2008 6:30 pm
i was talking about 10.5 inches wide.. whats the difference in 10.5 and 10.5W or is that what you talking about to... CT where did you get your hood from?
PostPosted: Thu Jul 31, 2008 9:00 pm
28/10.5/ 15 slick with 8.5inch rim and 4.5 basckspacing will work u have to grind the frame smooth all the way across, fold the inner fenderwell lip in, and bea the ineer tub so the tire its then frame first
here is an old pic of mine
PostPosted: Sat Aug 02, 2008 8:55 am
the hood i got from unlimited products or up as is referred on here, not the greatest quality hood, it needed alot of work to make it a good quality hood which i did not really care about, i would recommend getting one from somewhere else
PostPosted: Mon Aug 04, 2008 2:22 pm
where do you recommend gettin one from.. i havent seen another site on here that sells them.. i may be overlooking them tho
PostPosted: Wed Aug 06, 2008 4:08 am
what about harwood... i thought they had one?
PostPosted: Wed Aug 06, 2008 4:11 am
I have found no one other than unlimited at this time that makes a LUV hood. I haven't been able to find where the ebay seller in Tx is sourcing his yet. I have checked with Harwood, VFN, Hairy Glass, as well as others. I am mostly searching for a bolt on cowl hood though...
PostPosted: Wed Aug 06, 2008 8:49 pm
a bolt on would be fine with me i mostly want it for the look... but i dont wanna buy one and have to do work on it to make it look good either ya know.. i guess i could always use my org hood and buy rthe scoop from jegs.. probably would be cheaper havent really checked into it but it food for thought huh
