It is currently Tue May 26, 2026 11:16 am
PostPosted: Tue Jul 22, 2008 10:46 pm
eather would be bad but waundering any past problems or sugjestions..:) thanx
PostPosted: Tue Jul 22, 2008 11:27 pm
If the 410 is a bored out small block 400, stay away from it. the 400 sbc has married cyl. walls and tend to warp. IMO Your better off with a bored out sbc 327, 350, or whatever. Just not the 400.
PostPosted: Wed Jul 23, 2008 9:49 am
Which do you have the most parts for on hand? Aftermarket block or no? What head choice? I personally have had pretty good luck out of the factory 400 blocks, but that's just me...
PostPosted: Wed Jul 23, 2008 10:18 am
I am running a 400 as well. I have no probplem with the cooling but I do need a larger elec fan. There are certain things that should be done to relieve the coolant flow, like a certain head gasket and a certain hole size in the head.
PostPosted: Wed Jul 23, 2008 2:00 pm
True. My experience with that block is in stock pick up trucks pulling ski boats and stuff. Built and in a LUV is probably a different story.
PostPosted: Wed Jul 23, 2008 5:14 pm
well i was thinking some pro topeline heads with just a stock redone 400 but throw a bad dude 350 crank in her to give it a nice torquey 377... or icould just bore a 400 out a bit but put the same heads on... i was thinkin of just runnin motor for now and when i get her nice and hooked up then drop a blower or twin turbo it... nice
