It is currently Wed Jun 03, 2026 10:11 pm
 Post subject: 2wd? or 4wd?
PostPosted: Sun Jun 22, 2008 12:54 pm
so i have a 80 luv 2wd and a 79 4wd. the 79 frame is trashed and i want to switch the 80 4wd and wanted to kno if there anything different in the frames and place of casing that i need to watch out for.plz help it only my second car and i dont want it to get messed up.
 Post subject: Re: 2wd? or 4wd?
PostPosted: Sun Jun 22, 2008 8:41 pm
I am not sure on the answer to your question, I never had a 4X LUV, but was just curious if your avatar was your first car!!!! 8O :ebiggrin
PostPosted: Sun Jun 22, 2008 10:56 pm
I think he wants to know if the frames are the same between an 80 2X and a 79 4X4. He wants to put all the 4X4 stuff on the 2X frame because the 4X4 frame is junk.
I think they are different, but I don't know for sure. Someone else here will agree or confirm my ignorance. :lol:
PostPosted: Mon Jun 23, 2008 4:10 am
Australian LUV Guru
4x4 and 2wd frames are different, the 2wd frame has a different lower control arm and shock arrangement than the 4x4. The 2wd frame has a under engine crossmember whereas the 4x4 uses the axel housing as crossmember, the 2wd frame does not have the mounting points needed for the axel housing.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Mon Jun 23, 2008 10:12 am
Only if you want to convert to straight axles, like out if a Toyota, or Jeep or something like that. They call it SOA, sprine over axle. There is a lot of information on this. It takes quite a bit of work and some money too.
Good luck on your truck
PostPosted: Tue Jun 24, 2008 5:37 am
Australian LUV Guru
I agree with Papa G in the post above, the 2wd frame would make a good candidate for a solid axel conversion.
PostPosted: Fri Jul 18, 2008 7:37 pm
no thats wasnt my first car its at a roll over compation at at hyperfest at summitpoint
