It is currently Fri Jun 26, 2026 12:08 am
PostPosted: Mon Jun 09, 2008 9:42 am
Has anyone installed a Hurst Pro matic 2 or something close? The one I have is a pro matic and it was used and I do not have any instructions on how to install. Mainly on how to mount it to the floor board securly , and all I have is just the shifter and the cable, no brackets.
Any advice would be great.
PostPosted: Tue Jun 10, 2008 8:09 am
bama i just mounted mine to the trans tunnel, you may have to put some spacers to level it out and you can mount it a little angled if needed. make sure to put a thick washer on the underside for more stiffness.
PostPosted: Tue Jun 10, 2008 8:19 am
here's a picture.
PostPosted: Tue Jun 10, 2008 2:19 pm
CT you the man.
Thanks for the advice and pictures. Would you recommend installing before the engine and trans go in so the washers can be installed underneath
PostPosted: Tue Jun 10, 2008 9:07 pm
Well mine is a B&M but looks very similar, I had to massage the tunnel to match the mounts on the shifter, then trim the plastic base to match the contours, was pretty simple. Definatly install it before you have the tranny in, a lot easy to bolt down that way. Like CT mentioned. use some large washers to make it more stable. Mine vibrates side to side a little at idle.
It makes it easier also if you have a friend that will do this too! :ebiggrin
PostPosted: Tue Jun 10, 2008 10:05 pm
LOL...unchain that guy and turn him loose before someone calls the cops!
PostPosted: Tue Jun 10, 2008 11:12 pm
Nice looking shifter Tilted, but do you really need it for that 1 manpower engine?
PostPosted: Tue Jun 10, 2008 11:18 pm
That photo of your buddy is classic... a good tag line would be 'Money Pit'?....lol...
PostPosted: Wed Jun 11, 2008 7:14 am
Thanks for all the pictures , post and laughs :lol:
PostPosted: Wed Jun 11, 2008 7:18 am
Sometimes if you know the model and or number of the shifter, a lot of companies have on line manuals.
I don't know if Hurst does? Sometimes other places might too.
I found one on a a/c thermostat in my house!
PostPosted: Wed Jun 11, 2008 7:20 am
I think I have found it before. I just need to search again. If I do find I will post it here.
PostPosted: Wed Jun 11, 2008 7:31 am
I do better with pictures today..
PostPosted: Wed Jun 11, 2008 8:15 am
Nice photo CT. Good work.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Wed Jun 11, 2008 8:41 am
thanks fullaluv.
PostPosted: Wed Jun 11, 2008 9:04 pm
Yes, but I please dont ask about how to hook up the cable! 8O :oops:
PostPosted: Thu Jun 12, 2008 12:38 pm
Cables? Cables? We don't need no stinking cables!
There are some wonderful cables called morse cables. They work great for a lot of stuff.
PostPosted: Thu Jun 12, 2008 12:42 pm
Looks like marine cables are fairly cheap.
http://www.shipstore.com/SS/HTML/MOR/MOR33C.html
