It is currently Sun May 10, 2026 12:55 pm
 Post subject: 4x4
PostPosted: Thu Jun 05, 2008 6:35 am
Whats the biggest tires size I can use without lifting the truck, will have to move to 15 inch rims, 14 are hard to come by these days?
 Post subject: Re: 4x4
PostPosted: Thu Jun 05, 2008 9:35 pm
Australian LUV Guru
You cant fit much if your not prepared to lift and trim, A torsion bar lift and longer shackels ain't hard to do, niether is trimming the fenders.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu Jun 05, 2008 10:43 pm
i have a vary mild lift (i think 1") and i trimmed my fenders back a bit. I have run 30" tires but they rubbed alot, i curently am running 27x9.50R15 Super Swamper SSRs. They dont rub except when the truck is flexing, alot and i try to turn. I did run a set of P215/75R15s stock for a wile. They would rub if i hit a big rock in the road though. I just trimmed the fenders back a bit and ran that way for years. You can also put a baseball bat on top of your tire (once you have the larger size) and roll the truck so the bat gets forced between the tire and the fender. That will give you enough clearnace untill you have time to trim the fenders.
PostPosted: Fri Jun 06, 2008 12:28 pm
I just want to replace the 14 with nice wheels and an alterrain tire, really don't want to lift it or cut the fenders
PostPosted: Fri Jun 06, 2008 10:06 pm
i had on mine 28 8.5 14's TSL's they rubbed with no lift they only rubbed turning till i hammerd hhhmmm masage the wheel walls a little
PostPosted: Fri Jun 06, 2008 10:27 pm
http://www.miata.net/garage/tirecalc.html
This calculator will let you figure out the profile you need to run the 15" rim without going to a larger size outer diameter tire. Essentially, if you drop the sidewall profile by one series, you should be able to put the 15" rims on without having to change anything else. If you are running 75 series, 14" tires then you'd want a similar footprint (width) in a 65 series 15" tire. Watch for width, as you may still get some rubbing in front if you go too wide.
Good luck :)
PostPosted: Sat Jun 07, 2008 10:50 am
only problem with that is most all terain tires only go down to about a 28" diameter. So if you want to run a more off road tire youre probly going to have to do something to the backside of the front fenders...
PostPosted: Sat Jun 14, 2008 12:31 pm
I am running 235/75/15's and they working fine on the street except under hard braking. I do get more rubbing when off-road. If you are totally against cutting/trimming, then get about an inch from your torsion bars and then put on stiff shocks. Less shock travel will definately help your cause.
Emo
PostPosted: Tue Jul 29, 2008 9:54 pm
i just put some shackels and rised the torsion bars. i can fit 30 9.5 15 under it with no rub. and its a lot easier to get in and out of
I R REDNECK
PostPosted: Sat Aug 02, 2008 10:20 am
With a lot of trimming, about 5 inches, you can fit 33X12.50 pretty easy. I also have longer shackles and cranked up torsions.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Mon Aug 04, 2008 12:55 am
Torsion bar lifts aren't the greatest thing for these trucks... Wears things out, and if you haven't noticed, they don't make parts anymore... best bet is to get a beater 'Yota... pull the front end outta it... Pref solid front end... Good luck...
-ret
