It is currently Thu Mar 05, 2026 5:57 am
 Post subject: Hi from Montana
PostPosted: Sun Jun 01, 2008 8:08 pm
I have found some really good information on this site. I just bought a '79 4x4. It was on Craiglist. It was parked for 5 years tires flat and not running. Pulled it out of the mud. So far I have got it to run and taken around the block a few times. Bad fuel pump, bad relay, but fixed now.
Today when I drove around the block, I spotted another 79 or 80 4x4 luv parked in a yard full of brush and does not look like it has moved for awhile.
My truck is missing the emmisions parts Air Pump, etc, not sure if this is a real big deal, any advice?
My dad had a new 80 luv when I was young.
If anyone in Billings, MT has a LUV and can help I would appreciate it.
 Post subject: Re: Hi from Montana
PostPosted: Sun Jun 01, 2008 9:07 pm
Welcome. You only need the smog pump and other parts if your state, county, city require you to pass smog checks.
PostPosted: Tue Jun 03, 2008 9:42 pm
Thanks. The more I drive it and get the carbon blown out the better she runs.
PostPosted: Tue Jun 03, 2008 10:11 pm
Running out the old gas helps. There is stuff you can put in the tank to help the old gas run better. I don't remember the name. It helped with a lawn mower that sat up. Check with your auto parts store.
HTH
PostPosted: Wed Jun 04, 2008 8:18 am
Welcome to the one place online where you can find all the help you need and then some. :signwelcome
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri Jun 06, 2008 5:14 pm
well sea foam will help with the gas and carbon problem
PostPosted: Fri Jun 06, 2008 10:26 pm
I'll give it a shot. I think it's just the carb. One day it runs good, next day exhaust backfires. Mostly stalls when comming to stop when it is running bad. Thinking EGR rplacement. I replaced all the vacuum lines and checked the timing.
PostPosted: Sun Jun 08, 2008 7:21 pm
Thats it... It just doesn't seem like a name for something that does that...
PostPosted: Sun Jun 08, 2008 8:55 pm
They are not kidding when they say it smokes. We'll see how it does. Just got new rubber on her and going to drive it to work tomorrow.
