It is currently Sat Dec 13, 2025 7:25 pm
PostPosted: Thu May 29, 2008 6:16 pm
i have a 79 4wd with a header. my clutch cable froze down by the exhaust header. i called about some header heat tape stuff and right now its too expensive any body know any other ideas? dose anyone have this problem? is that what actually caused my calbe to freez? what else would?
PostPosted: Thu May 29, 2008 6:59 pm
i have the header on mine and never had a problem, sometime the cable will fray at a end and cause it to freeze up or dirt that got into the cable ends
PostPosted: Thu May 29, 2008 7:12 pm
i would rather have the cosworth than anything! even any v8 i would LOVe to get my hands one one ofthose till i needed to fix it.
PostPosted: Thu May 29, 2008 8:35 pm
i see them from time to time on craigslist for $300 to $1500 for the motor.. i sure hope i can get it in this summer but i am sure it will be by next summer, need to build the hole truck.. they are just a vega block with a cosworth head, all parts are vega in the block and trans.
PostPosted: Fri May 30, 2008 11:39 am
You might try some heater hose on it. See it you can pull away the cable from the header.
Real dry cable could cause it to stick. Have you freed it up. If so and you can get the cable out. You might me able to grease it. Try using High Temp Disc brake wheel bearing grease.
You could try to make a metal heat shield from some scrap metal.
Cable......... l
................l : l
................| : l
My ASCII Artwork sucks
Where there is a will, there is a way....
Not only this way, but it might work.
