It is currently Mon May 25, 2026 8:05 pm
 Post subject: frame swaping
PostPosted: Thu Apr 24, 2008 5:50 pm
has anyone seen or know if you could put a 78 luv body on a 90-00 s-10 frame
 Post subject: Re: frame swaping
PostPosted: Thu Apr 24, 2008 6:13 pm
Are you swapping a v8 also?? I would stick with the luvs frame if you are way stronger!!
6.0l ls1 swap th350
PostPosted: Thu Apr 24, 2008 8:29 pm
Anything can be done with a torch, welder and a little imagination and know how
PostPosted: Thu Apr 24, 2008 10:49 pm
aint that the truth!lol :lol:
6.0l ls1 swap th350
PostPosted: Fri Apr 25, 2008 10:04 pm
well my thoughts were to lay the frame and there is al ot more suspension options front end wise i could go with and the back i was going to cut it off and put a custom four link. i was going to do the v8 but with gas going up and not down i think i might make it a cool dd and stick with a newer 4. if its not to bad and things line up well it will help with the z06 wheels i have to put on it
PostPosted: Sat Apr 26, 2008 6:07 am
Not sure but if you are not doing the v8 it could work. Luv frame is a lot stronger and you could swap in the rear end very easy but the front end would be a lot more work.
Would be neat to set the luv on an s-10 frame and have all the 5 lug setup stock. Lots of ptions as you say.
PostPosted: Sat Apr 26, 2008 12:09 pm
like litemup says with a torch welder and imagination any thing can be done.i have a buddy that has a luv bed and cab on a toyota 4x4 chassis looks factory.also theres many s-10,s and luv,s both running around with v-8,s so i dont see why the v-8 swap couldnt be done.brandon says the luv frame is stronger i dont know,i do know the s-10 frame is heavier.if it was me i would go with the bigger engine v-8 or atleast a 4.3 v-6 if it's not going to be your only ride.if it's going to be your only ride i would do a 4 banger.why are you wanting to use the s-10 frame over the luv frame.you can 5 lug the front and rear of the luv for your z06 wheels but the s-10 does have way bigger wheel wells.i have an s-10 at my place now im working on 4 someone and it's been lowered 3 inches front and rear and still has more wheel well room than my luv has.if this is something your wanting to do go 4 it i dont see any reason it wont work.
When buying a used car, punch the buttons on the radio. If all the stations are rock and roll, there's a good chance the transmission is shot!!!
