It is currently Fri May 08, 2026 2:37 am
 Post subject: Weber 32/36 adapter
PostPosted: Thu Apr 17, 2008 7:07 pm
Got this adapter to install a weber on the luv:
http://www.jameng.com/products/images/99004.250.jpg
Does not look like it will work. Should I have gotten this one?
http://www.jameng.com/products/images/99004.300.jpg
 Post subject: Re: Weber 32/36 adapter
PostPosted: Thu Apr 17, 2008 10:39 pm
the one you got is the better one of the 2
PostPosted: Thu Apr 17, 2008 11:37 pm
On the one I have, the bolt holes match up for the weber carb, but the other end does not match up, with the stock carb. I have a spare carb that I was matching it up to. Have not removed the carb from the truck yet.
PostPosted: Fri Apr 18, 2008 12:35 am
what one was that for? i was told datsun and luv where the same..., i have seen them on the luv
PostPosted: Fri Apr 18, 2008 6:53 am
Here are the discriptions for the 250 and 300:
99004.250: Toyota, Chevy Nova carb adapter.
Adapts DGV series Weber carbs to Toyota and Chevy Nova manifolds on 2TC, 3TC, 4AC, 4AGE, and 4ALC engines. Manifold studs measure 4.405" x 2" (112mm x 50mm) center to center.
99004.300: Nissan, Suzuki one piece carb adapter.
Adapts DGV series Weber carbs to some Nissan and Suzuki manifolds. Manifold studs measure 3.150" x 1.740" (80mm x 44mm) center to center.
Measured the bolt holes on the spare carb, they are 3.150" x 1.740" . The 300 should work. They also have a two piece adapter that shouild work(333) .
99004.333: Japanese two piece carb adapter.
Adapts DGV series Weber carbs to some Chevy Luv, Dodge Colt/Champ, Ford Courier, Isuzu, Mazda, Nissan, Suzuki & Toyota mainfolds. Manifold studs measure 3.150" x 1.740" (80mm x 44mm) center to center.
Think I'll give that one a try. It even lists the Luv for the 333.
PostPosted: Fri Apr 18, 2008 10:31 am
the .333 is the one most every one has on the luv, its what i have right now...but if you ever find a hi rise one for the luv snag it they work better
PostPosted: Fri Apr 18, 2008 5:50 pm
I kinda hae a related question but couldnt you build a spacer for a highrise or would there be issues that i am over looking?
-dustin
PostPosted: Fri Apr 18, 2008 9:45 pm
yes you could ...just use some 1 or 2 inch aluminum stock... should be easy
