It is currently Thu Jun 25, 2026 1:21 pm
PostPosted: Sat Apr 12, 2008 11:00 pm
i just pulled the motor out of my truck. im going to go all new gaskets and bearings. what do i use to clean the engine with and what paint works best?
PostPosted: Sun Apr 13, 2008 1:21 am
Easy off oven cleaner and the local car wash works well. Just be sure to thouroughly dry the cylinders so they don't rust adter you're done. I use most any rattlecan engine paint with good results.
PostPosted: Sun Apr 13, 2008 1:33 am
I just finished this one today for a customer and used regular hi temp semi gloss on the block and timing cover and flat black on the valve cover
on this one I used hi temp black for the block , silver flake for the aluminium parts and a 2 part (siver base , red top coat) for the valve cover.... the silver and red where not hi temp and have held up fine over the last 2 ot 3 years...
PostPosted: Sun Apr 13, 2008 1:50 am
Might want to look through this thread...
viewtopic.php?f=5&t=12890
PostPosted: Mon Dec 13, 2010 11:03 pm
I know this is a old posting but Cat.... how did you get the aluminium that clean on the motor you did for your customer? Yes I read about the oven cleaner but have heard many negatives on the effects of alumium.
PostPosted: Tue Dec 14, 2010 3:20 am
just engine cleaner and a hard brush with a lot of elbow grease ...
PostPosted: Tue Dec 14, 2010 8:08 am
Looks real niice CatMan.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Thu Dec 16, 2010 11:33 am
VHT engine paint is the best I have seen but make sure it is clean!
