It is currently Thu May 07, 2026 1:30 am
PostPosted: Mon Apr 07, 2008 10:18 pm
My 96 s10 just had a fire that ruined most of the truck besides the engine. I just got a 78 LUV 2wd with a perfect body and no engine for free. I was just curious if the LUV frame was very strong?? I will be running a 12 point cage to help stiffness. The engine is a 377 chev with hendricks sb2.2 heads Fast XFI and a Precision Turbo 106mm turbo. The previous truck it was in wheel dyno'ed at 1435hp on alky is the LUV frame strong enough to take that kinda power? Also the six lug front has to go. I still have Weld alumastar 2.0's from the s-10 I would like to run on the front. I have read a little about Aerospace components 5 lug conversion have any of you tried this setup?? And if so is it a good setup? And any info on the front coil over conversion would be very helpful. Thanks for any info.
PostPosted: Mon Apr 07, 2008 10:47 pm
A recent Aerospace thread:
viewtopic.php?f=7&t=15387&hilit=aerospace+kit
One of several coil over threads:
viewtopic.php?f=7&t=13278&hilit=aerospace+conversion
I've no idea what the frame can handle, but you are in good company here on the site. There are several seriously high HP trucks and owners here.
Welcome!
PostPosted: Tue Apr 08, 2008 1:09 am
The LUV frame is stronger. It is fully boxed whereas the S10 is not. It also has a few more crossmembers so it is also stiffer.
PostPosted: Tue Apr 08, 2008 11:20 am
Very helpful stuff guys thanks. My engine is sittin on the plates and down in the frame as of last nite. I will try and get some pics of this project up as soon as I get the new headers fabbed and try to find a place to sqeeze this turbo in. There isnt quite as much room as an s-10 under the hood. Has anyone tried a radiator mounted in the bed??
PostPosted: Tue Apr 08, 2008 1:32 pm
Here is a link to installing a larger radiator up front...
http://www.getphpbb.com/phpbb/viewtopic ... 0dragracer
PostPosted: Tue Apr 08, 2008 6:05 pm
I was thinkin the bed would be a good place for the radiator so I can hang the turbo in place of the stock radiator.
PostPosted: Tue Apr 08, 2008 6:22 pm
Check out this thread ......viewtopic.php?f=24&t=15832
PostPosted: Tue Apr 08, 2008 9:42 pm
Nice. I hope my shogun water pump can move the coolant that far without any probs. Mounting in the bed also gives room for a large radiator
PostPosted: Mon Apr 14, 2008 5:57 pm
turboluv the aerospace is a good setup i use it on mine and have no problems other than the stock luv master cylinder not having enough pressure without pumping a time or two, it's a very easy and straight forward install. i had a thread on here some where that showed all that came with the front and back kit, the name of the place was autofab racecars i think in maryland but google it and it should pop up. anything else you need just holler.
PostPosted: Mon Apr 14, 2008 8:19 pm
I had planned on using the chrysler master cylinder from the s 10. I had wilwoods on the rear and aerospace on the front and with manual brakes it would put ya through the winshield at normal driving speeds. the turbo is goin to fit perfect in place of the radiator so fabin up the headers wont be as bad as the s 10 was. I ordered a 12pt cage kit from jegs today so hopefully this thing will be ready for the street before long
PostPosted: Tue Apr 15, 2008 4:11 am
that master should work fine, that is what aerospace more or less offers for there setup.how much was your cage from jegs with shipping, the 10 or 12 point is my next project after the ladder bars are done.keep us updated and post some pics if you get a chance...we luv to see progress on projects.
PostPosted: Fri May 16, 2008 9:37 pm
we are currnently doing the same set up true ten five tire class small block chevy with a 91mm turbo 25.5 cage here are a few pics cage is getting put in next week
ROBBIEE...
PostPosted: Fri May 16, 2008 9:43 pm
Nice...
PostPosted: Mon May 19, 2008 4:08 am
looking good, what size hoosier are those.
PostPosted: Mon May 19, 2008 10:17 am
Man, that is sharp! I really like those front rims...
PostPosted: Thu May 22, 2008 1:34 am
True tens .
How did I miss this one . WOW !
PostPosted: Thu May 22, 2008 4:17 am
hotrod80 wrote:
True tens .
they just didn't look like a 10" tire,hotrod quit working so much and get to reading the site....i've been working to much and not on here at all lately.
PostPosted: Sat May 24, 2008 12:04 pm
they are true ten fives butwe are going to order some m/t 29.5/10.5/15S becasue they have a stiff wall design also putting single beadlock on the back wheels should have some pics to post of the cage work in about a month
check this pic out they are real small
robbie..
Users browsing this forum: Bing [Bot] and 26 guests
