It is currently Fri Jun 26, 2026 1:47 am
PostPosted: Sat Mar 29, 2008 12:14 am
one of my friends has a 20R pickup 2wd 4spd with weber. he thinks its so fast. i want to kick his ass with my 4wd luv:D i have header 2,1/4 exhaust with 32/36 same carb? what will it take and do i have to do bottom end if i turbo the luv engine. or just the g200 head?
PostPosted: Sat Mar 29, 2008 1:00 am
read this http://www.chevyluv.zoomshare.com/1.sht ... your%20luv
PostPosted: Sat Mar 29, 2008 2:21 am
NICE im going to try it i wonder how a system would work if it blew threw the carb?
PostPosted: Sat Mar 29, 2008 9:12 am
not sure on that one
PostPosted: Fri Apr 04, 2008 11:35 am
Aaron you would be fine with a blow through setup. We are in the process of putting 8psi on my sons stock 76 truck using a T3 on a custom manifold, you don't need an intercooler till you get up over 8psi, but we are fabbing up a cooler. If you are serious let me know, I can send you some pics of where we are so far.
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
PostPosted: Sat Apr 05, 2008 7:47 pm
anybody know of a preformance clutch that will fit the luv? something with out springs would be cool
PostPosted: Sun Apr 20, 2008 2:58 pm
If you got the 4x4 then your luv will also have the larger flywheel, keep in mind the measurements and look into mabye something for a pu'p/trooper i know they a got a way bigger aftermarket than there is for the luv, also might try asking farmer joe if i remember right a while back he was saying somehting about a clutch disk that is made for a 4x4 that he runs in a 2x4 dont quote me on it but im pretty sure he was the one talking about it...
Also the stock bottom end is quite rugged, the crankshaft and connecting rods are tough and if you ever get a g180 apart they look pretty beefy...
-Dustin
:edit: I almost forgot the only way i would thing that you would wanna use the G200 head is if you planned on running ALOT of boost but 5psi should be find for the stock engine, i wouldnt think you would have any problems
Users browsing this forum: Baidu [Spider] and 35 guests
