It is currently Mon Jun 29, 2026 11:58 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2, 3  Next
 Post subject: I got a Luv again
PostPosted: Mon Feb 18, 2008 8:02 pm
Well thanks to nukeday :) I am back in business with a luv truck againImage
although not the best shape it makes for a fun project. His build inspires me to build a small block chevy actually. I have a good block and transmission for the build. He mentioned that I have a lot of parts which still do which will come in hand for what I have brewing for the transplant.
if I do
my idea is to gut most of the parts down to the chassis.
-350ci/th-350 (i know typical huh!)
-tilt front end- with extended fenders (plan to cut out core support and both inner fender wells for easy access)
I will brace somehow though with all that mumbo jumbo I thought I may use the hood latch assembly to latch the full front tilt keep it simple!
-build a new bed for back (step side style) and have a tilt for it as well.
-need to form up some rocker panels and weld in place which I have done before P.I.T.A :x
-coil over front suspension
-removeable transmission x-member (like the idea i heard on the board)
-find a rear axle install choices (9", 8.8", dana 35 or 12 bolt) may just keep stock in for a while and if it blows up i have another :)
-make a drive shaft
-gut all cab glass and parts inside
-dash modifying
-body work (body filler,primer and such)
-paint and under coat
-engine and transmission overhaul
-electrical and plumbing
-new rubber like grommets, molding
other nickle and dime items im sure of
and work bugs out which will take some time!
 Post subject: Re: I got a Luv again
PostPosted: Mon Feb 18, 2008 8:13 pm
Awesome! I know you have some fab skills...can't wait to see how it goes. :)
We'll have to get together again in a year or so...lol...
PostPosted: Mon Feb 18, 2008 8:26 pm
well if you need some help with your build I am down. sometimes it takes an extra hand I might not make it up very often but definitely am down for it just for fun
I stole your pic by the way.
PostPosted: Mon Feb 18, 2008 8:45 pm
Looks like a good find. Good luck on your project. You will have to keep up posted with pictures.
PostPosted: Tue Feb 19, 2008 12:40 am
Sweet....
Good luck in your finds for stuff.....
"find a rear axle install choices (9", 8.8", dana 35 or 12 bolt)"
I found me a 9" for 20 bucks....no kidding.... :esurprised
Found another one yesterday for 300....
I guess one mans trash is anothers treasure
PostPosted: Sat Mar 15, 2008 7:09 pm
So I am in the process of having a another luv with most of the work listed above already done which will save me some time and money. So hopefully I get my truck sold soon to snag this one up wish me some luck! :esmile
PostPosted: Sat Mar 15, 2008 8:52 pm
good luck!!!!
PostPosted: Sun Mar 16, 2008 8:58 pm
looks pretty clean man..hell of alot better then my 79 Luv long bed looks curently lol
Stick Shift Racing
PostPosted: Thu Mar 20, 2008 5:41 pm
o k I'm getting the luv this weekend woo hoo! I will be broke for a while but its okay :)
I ll post a thread with luv parts for sale stuff I have more parts again haha!
Pics will be coming soon!!!
PostPosted: Tue Mar 25, 2008 8:18 pm
got my luv
truck today and it has alot of power for needing tuned up it needs timed carburetor gone through and possible other spots. I noticed that the truck gets really jumping around over bumps when your traveling fast kinda. I m gonna snap some pics here in a minute of it really stoked about the truck woo hoo!!!!! :D
PostPosted: Tue Mar 25, 2008 8:28 pm
congrats
PostPosted: Tue Mar 25, 2008 8:46 pm
PostPosted: Tue Mar 25, 2008 11:01 pm
o k the shocks in back are not any good that explains the ride home being crazy. the belt is a little too loose needs different belt or i would have to mess up the chrome alternator bracket. edelbrock is a little too rich and Im going to check the timing and see if I can't rob shocks off the parts truck :P
and heres the pictures
PostPosted: Wed Mar 26, 2008 12:30 am
Nice! Now, what's under the tarp...
PostPosted: Wed Mar 26, 2008 6:04 am
That is want I was thinking!!!
PostPosted: Wed Mar 26, 2008 7:19 am
that's funny you should ask my neighbor has a vega with a 305 in it just it needs paint and his oil pan gaskets keep going out so he is waiting on a part to fix that because there is to much pressure in the crankcase I guess? He was like whoa that yours he likes it.
PostPosted: Wed Mar 26, 2008 11:38 am
Stepside, lambo doors, V8 and a flip front, front visor, tonneau cover, scoop... 8O 8O 8O
Wow, that's a nice score. :ebiggrin Congrats!
We definately need to hook you up with some proper shoes, still I'm diggin' it...
What do you have in mind for paint?
Now that we have a template, wanna' do a flip front on mine? LOL...
PostPosted: Wed Mar 26, 2008 12:36 pm
and for any one that may want to try the tilt front end here you go
http://www.chevyluv.zoomshare.com/1.sht ... ront%20end
PostPosted: Wed Mar 26, 2008 2:49 pm
wow how much $$$ that cost yah?cuz it looks damn sexy even 8) with shitty paing
PostPosted: Wed Mar 26, 2008 5:34 pm
yeah I love the truck I uh got it for $1350 lets keep it on the down low
and yes i wouldn't mind helping you do a tilt front!!!
paint wise well its crazy Im gonna first just for now shoot it with some my dads trailer paint gloss black but later paint it with some candy apple red
it needs the following
-shifter worked on (might spring for a b&m or hurst dont know yet?)
-shocks (temporarily I will rob the ones off the truck from nuke)
-new belt the old one is too loose
-exhaust manifold possibly or gasket I have a leak I can hear (my neighbor has a manifold)
-hood pin locking device
-paint job along with some body work also front tilt revision
-new tonneau cover for bed (its a bit ratty)
-running lights for the back (or wiring)
-guages need hooked up (dont know the speed or volts or temp) have the tach and oil pressure
-carb work tuning
-timing checked
-bring the firewall back and notch out spot for the distributor
-wiring
-heater
-stereo hooked up
-wheels and tires later on
-fuel cell
-headers
-coil over conversion
-brakes upgraded that aero kit for the front looks good from the thread I seen
-9" maybe down the road
and nickle and dime stuff I m sure of
I have a crap load of parts to work with though and some I can part with
maybe we can trade for some of the above Hmmmm?
thanks for the comments
Users browsing this forum: Google [Bot] and 22 guests
