It is currently Mon Jun 08, 2026 10:27 am
PostPosted: Sat Jan 19, 2008 2:54 pm
Pulled spark plug brought cylinder to top dead center,checked dist for fireing order ,mind you this truck ran prior to me trying to adjust the points . so i set points. got spark and fuel still wont run.....
PostPosted: Mon Jan 21, 2008 1:17 am
Try spraying some electical contact cleaner at the points, letting them dry and fire it up. Or, some alcohol. You may have touched the points and gotten them oily. It doesnt take much to make 'em not fire. Make sure you didn't leave the capacitor unhooked (little metal cylinder in the distributor, with wire to it at one end). Also clean the contact tip of your rotor.
PostPosted: Mon Jan 21, 2008 1:20 am
Wait, you say you HAVE spark to the plug? Did you try to loosen the distributor reset the timing for some reason? Sounds like maybe timing is now off.
PostPosted: Mon Jan 21, 2008 9:07 pm
Thats what I PM'd him. I told him to double check firing order, and asked if he pulled the distributor out or lifted it up at all. Maybe its 180 degrees off. If that all checks out, I said to check compression, although that seems unlikely since it ran before he touched the points.
No LUV anymore, but still in the GM truck family. Running a lifted 2002 Silverado Z-71!
PostPosted: Thu Mar 06, 2008 7:23 pm
I know this thread has been dead for awhile, but I was wondering how this turned out. Did you get the truck running good? Still having problems?
PostPosted: Fri Mar 07, 2008 2:27 am
just a point to add, you can't get the distributor in 180 degrees off, the shaft will only fit the right way. It is really easy to get the cam timing 180 off tho, which gives the same result. So it is worth trying to swap the plug wires across from each other.
PostPosted: Sat Mar 08, 2008 12:15 am
Yeah I wasn't positive about that. I've only torn into a LUV engine once and its been awhile. I was assuming it was like a SBC, where you could drop the distributor down in the wrong spot.
Thanks for the correction
Users browsing this forum: Google [Bot] and 26 guests
