It is currently Mon May 11, 2026 9:37 am
 Post subject: DAMN IT !!!!!!
PostPosted: Fri Feb 29, 2008 12:58 pm
i drove my truck today , ran around town a little then went outside town and opened it up , little truck pulls really hard , but when you let off it its like it floods out it was a b--ch to get it started , ive only got about 5-6 lbs of fuel pressure going to it right now, and when i got home i checked the oil and it smells like gas , any suggestions on where to start first , and 5-6lbs shouldnt be too much should it , i was thinking i was gonna have to run way more fuel pressure than that .oh yeah i am using an edelbrock carb , any suggestion would be great thanks in advance joe :?
junkyard racing - we win with your old parts
 Post subject: Re: DAMN IT !!!!!!
PostPosted: Fri Feb 29, 2008 1:58 pm
i don't know much about fuel pressure but i do know alot about blown head gaskets! hopefully this is not your case huh? i would take an educated guess and say that your pressure is to high! or just adjust your carb a little better!
Luv my Luv? I do!
PostPosted: Fri Feb 29, 2008 7:40 pm
Sticking float?
PostPosted: Fri Feb 29, 2008 10:04 pm
luvondope wrote:
Sticking float?
This is what I would guess. Or a piece of crap stuck in the needle and seat. I would guess the fuel pressure is fine. I run about 7 lbs of fuel pressure in my race truck. Is the choke plate opened all the way?? If you got gas in the oil, it pretty much has to be a carb. problem.
PostPosted: Fri Feb 29, 2008 10:21 pm
Or it could be the fuel pump leaking into the pan. But it would have nothing to do with it flooding out at WOT.
PostPosted: Fri Feb 29, 2008 11:12 pm
i run a electric fuel pump so i know thats not it , thanks though
PostPosted: Sat Mar 01, 2008 1:33 am
if the float was sticking wouldnt it load up all the time , and as for the needle and seat , the truck runs great idles good runs around town good its just when you really lay into it that it does this , all i know is ive got to figure it out it costs me around $40 everytime i change the oil , and that will get old quick, as ive changed it once after brake in and once already over this issue , i wish there was a chassis dyno locally i would just take it to them and let them figure it out , but then i wouldnt learn anything , thanks for the input joe ( anybody good at rebuilding holley carbs)
PostPosted: Sat Mar 01, 2008 1:46 am
Holley, there is your answer to the problem... :lol:
PostPosted: Sat Mar 01, 2008 4:25 am
Yep...get a good edelbrock or a carter.
PostPosted: Sat Mar 01, 2008 4:53 am
ive got an edelbrock on it , i was kinda thinkin that was the problem , ive got access to a good older carter , its on a built bb ford , i thought about a q-jet , i always thought that edelbrocks werent that good of a carb , maybe im wrong , i know nothing about carbs keep the info coming and thanks joe
PostPosted: Sat Mar 01, 2008 10:07 am
An Edelbrock is a Carter, they bought the tooling...
PostPosted: Sat Mar 01, 2008 11:36 am
I run a Holley 1050 Dominator double pumper on my race truck. They are very easy to rebuild.
PostPosted: Sat Mar 01, 2008 11:52 am
My personal preference is to run a Predator carb,that said, Holley is my next choice.They are easy to rebuild also.
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Sat Mar 01, 2008 12:42 pm
my buddy gave me 4 holleys and a torker intake , i put one of the holleys on and tried it , other than its leaking gas the motor sounded alot crisper and was more responsive so the edelbrock will make a good anchor for my 2 man boat and im in the market for a goooood holley not sure what size to get but hopefully i can get some info and suggestions from you guys well all the info ive gotten from the folks on this site has been great , hopefully one day i will be half as inteligent as alot of you guys thanks joe
PostPosted: Sat Mar 01, 2008 1:06 pm
New gaskets should take care of the gas leak. A few years ago I let a buddy use my Holley on his Dodge race car. Made a big difference and even picked up a few tenths!! He didn't even change the jetting. Just bolted it on his car and went to the track.
PostPosted: Sun Mar 02, 2008 6:41 pm
you can look up the numbers on the holley to see what it is,and just throw a gasket set at it.I like to run one with mechanical secondarys but that's just me.When i first did my v-8 swap i ran a 750cfm and it worked great.
[color=#FF8000]
