It is currently Mon Jun 08, 2026 11:36 am
 Post subject: What's this hose for?
PostPosted: Sun Feb 17, 2008 7:13 pm
I assume it's some kind of breather for purging the head.
On my stock manifold, there's a pressed-in 'bleeder' fitting. (It looks like it just allows a tiny bit of vacuum.) On my new Offy manifold, there's nothing.
I don't know whether to try to remove the fitting and somehow get it onto the new manifold, or just to plug the hose and forget it.
Any advice would be appreciated.
You went there in that?!?!
PostPosted: Sun Feb 17, 2008 8:45 pm
on mine have run them blocked off or gust down the side if the motor.. dont know if thats right or not but have never had a problem
PostPosted: Mon Feb 18, 2008 4:24 am
Australian LUV Guru
The little hose pictured push fits onto a fitting on the under side of the stock aircleaner housing, its ok to block it off as it will pump out a little oil vapour.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Tue Feb 19, 2008 6:31 pm
Nope. It goes right where it already is. Into the manifold. It lets the manifold vacuum suck fumes out of the upper half of the eng. and into the combustion chambers.
PostPosted: Sun Feb 24, 2008 9:13 am
Its actually part of the fuel vapour recovery. Its polution gear but not the type that makes motors go crap.
The G-series motor had no charcoal cannister they used the engine to deal with vapours.
I say air cleaner. In theory no open circuit vacuume source should be available to the carb. Especially not after the butterfly.
Bob.
PostPosted: Wed Feb 27, 2008 10:51 pm
Thanks everyone, but I know where it goes. It goes to a vacuum 'bleed' fitting on the intake manifold. This fitting only allows a slow bleed of vacuum.
My problem is that I don't know how to connect it to my new offy intake. As Rodeobob said, I can't connect it to a full vacuum, and I don't really want to try to extract the pressed-in fitting from the old manifold and jury-rig it into the new one.
I'm thinking I'll just let the hose hang when I put the new manifold on.
I was just wondering if anyone else had done that.
Also, I was curious as to its function, since there seems to already be a PCV hose.
Anyway, thanks everyone for your help.
PostPosted: Sat Mar 01, 2008 2:27 am
It is the engine venting system. Draws vapors from the crankcase and valve cover, into the manifold for burning with the fuel mixture. It is a small metered orfice with no PCV valve used. The hose to the air cleaner is the fresh air inlet into the engine.
PostPosted: Sat Mar 01, 2008 11:38 am
Ohhhh, OK.
That makes sense now.
Thinking this through, if I leave it hang, there's a possibility I could suck dirty air backwards through the hose into the engine, and then into the carburetor through the big hose.
Sounds like I should find a metered orifice and use it.
(If one had a dirty mind, they could see a lot of obsene innuendo in those comments. Lucky I don't.)
Thanks.
PostPosted: Fri Mar 07, 2008 7:50 am
Ah, yes, the metered orifi. that makes sense.
(insert rude comment about wife)
Just plumb it in to the air cleaner between the cleaner and the butterfly/venturi. Should see enough suction to work well enough. No worries about dirt then.
Bob.
Users browsing this forum: Bing [Bot] and 65 guests
