It is currently Mon Feb 02, 2026 12:53 am
 Post subject: What rearend did I find?
PostPosted: Wed Feb 13, 2008 4:23 pm
I took some measurements and some pics (I will post them later).
The length from the ends of the tube is 6.375.
It has mounts for coil springs.
Ring gear has 45 teeth and the pinion has 18 teeth.
So thats a gear ratio of 2.5:1 (I havent heard of a 2.5 before)
The back side of the houseing has 2 dimples.
I took the ring gear off, but I need to know where to measure it, from the outer most sides of the teeth?
I also took some numbers off of it, but they dont mean much to me.
G7AW E 57
8A20
Anything else I should measure or look at?
PostPosted: Wed Feb 13, 2008 4:36 pm
is this a Ford 9 you're refering to? If so sounds like you have a car version, probably a 28 spline. Does it have a drain plug? Does it have disc brakes? The only way i've ever really been able to find a R&P ratio is to do it old school: make a mark, spin it, and count....fun times
1975 LUV with a caddy 500ci, 12.5-1 comp, 850CFM holley sucking E85 through 110 jets and torquing the hell out of a TH400. Currently @ 6mpg
Bowties may be for little boys, but ponies are DEFINATLY for little girls....
PostPosted: Wed Feb 13, 2008 4:45 pm
The pics.....
PostPosted: Wed Feb 13, 2008 4:53 pm
I hope those pic's arnt too big for some of you.... Ill try and shrink them in a day or two..
There isnt a drain plug, but there is a filler plug on the third member about 1/4-1/2 way up on it.
Doesnt have any axles or brakes.
I dont know how to get the spider gears out from inside there, and counting the axle splines would be pretty hard to do.
PostPosted: Wed Feb 13, 2008 6:25 pm
i couldn't see in those pics, but does the 3rd member have an "N" on it. It would be on the outside like a casting number. Good score tho, regardless of age. The 31-spliners are what you want tho. Just finished shortening mine here the other day, LOOKED just like yours, but it had leafs, so no provisions for tracbars.
Also, almost forgot. Look on your ring gear and see if it has a FoMoCo part number on it. FoMoCo looks like the Ford symbol with and oval around it on the edge of the ring. If you can get a legible one i bet it may be a good Googler.
PostPosted: Wed Feb 13, 2008 9:42 pm
I found on the ring gear the Ford symble, it definatly said Ford in the circle.
After that it said SA D7AW 4Z BA 845
The Z might be a 2, it was somewhat missing.
PostPosted: Wed Feb 13, 2008 10:03 pm
Im wondering if its not an 8 inch because of this cover over where the U-joint would be....
This place has some different diffs, and comparing mine to theirs....
http://www.ringpinion.com/DiffList.aspx ... &Type=Ford
PostPosted: Wed Feb 13, 2008 10:27 pm
Welp, Im in the middle of doing some research and found this site.....
http://www.kevinstang.com/Ninecase.htm
Its looking like a 9" from what I am reading, and a very good one at that.
Mine is a C6AW case with a pinion guard.
PostPosted: Thu Feb 14, 2008 3:54 am
The larger pics helped. It's a 9 inch, not a nodular section though.
