It is currently Tue Jun 09, 2026 1:28 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Thu Feb 07, 2008 8:29 pm
thanks for the tips
PostPosted: Thu Feb 07, 2008 8:57 pm
djewett, if you accidentally hooked up to manifold vacuum instead of carburetor vacuum, it would cause the symptom you described. Just a thought.
Bob, I lived with rough idle for a long time until I discovered the brake booster was leaking. It ties into the manifold right at cylinder #4. A leak causes #4 to run real lean, while the others run richer, so there's no carb adjustment that works. Just a thought too.
You went there in that?!?!
PostPosted: Mon Feb 11, 2008 9:24 am
thanks for the tip... will bypass the booster and see
