It is currently Sun May 10, 2026 2:50 pm
 Post subject: Body Mount Bushings
PostPosted: Sun Jan 13, 2008 12:22 pm
I need any info available about alternatives for the rubber body mount bushings. What kits from other trucks (Toyota, Ford, GM) could be used?
1980 4X4 LUV
PostPosted: Sun Jan 13, 2008 4:15 pm
Ditto :)
PostPosted: Mon Jan 14, 2008 7:17 am
In not to sure on the pre 81 but after that they are the same as the trooper.
Being the same as the trooper id say they were the same bit as the pickup right thru into the late 90's.
Check that out.
If you can get a pic of the Luv one post it up, ive got a few trooper ones lying about and im about to lift the cab off an 84 or 85 pup.
Cheers, Bob.
 Post subject: Re: Body Mount Bushings
PostPosted: Tue Mar 04, 2008 4:21 pm
Ok, my dad is up at the place right now picking up the luv for me, he just sent me some pics :( holy crap, if this truck gets body hit, im affraid the cab would tare off the frame 8O
talk about rust...god damn it.
looks like i need to know how much a new driver and passanger floor welded in will be :cry: :oops:
but yah, new rubber seems to be in order for this.
PostPosted: Fri Mar 07, 2008 8:08 am
You might be able to zoom in a bit if you right click and save it.
This was the only pic i thought to take. When im up and my mates i will grab a few more if i think of it. Its an 85.
Bob.
PostPosted: Mon Mar 10, 2008 7:41 am
A friend of mine is redoing a 64 pontiac tempest and he is making his body mount bushing out of a Hockey Puck. He just takes a hole saw the same size as the orginal body mount and locks the puck on his drill press and he has a cheap replacement. They cost about a $1 or $2 each and they are universal fit. The stiffness is similar to a poly bushing. And you know if they can stand the beating of a hockey player they should last awhile.
PostPosted: Mon Mar 10, 2008 11:44 am
Hockey puck? That's similar to an idea I had while in the outdoor store. I was considering using a couple of boat trailer rollers, lathed and cut down. Same idea, but the hockey puck would require less turning.
Then there is always UHMW, I can get my hands on sawmill chain pucks pretty easily. Anyone know anything about plastic density?
PostPosted: Mon Mar 10, 2008 12:21 pm
The UHMW will give...
PostPosted: Mon Mar 10, 2008 7:09 pm
You need give.
The mount rubbers need to have enough flex. If they dont you will end up with cracks in the cab around the mounting holes.
Bob.
PostPosted: Mon Mar 10, 2008 7:37 pm
The give I'm talking about is it will compress over time, letting the bolts work loose.
PostPosted: Tue Mar 11, 2008 5:06 pm
I was wondering this too, since I will need new floors welded into both the passanger and driver side. Unlike my other luvs just passanger side. I think Ill need new bushies too. Not sure.
Looking into wheels atm :D
Ooooh the possibilitiesieisieisiesssss!
PostPosted: Tue Mar 11, 2008 11:57 pm
Thats why the have a metal collar/tube in between the two washers. This is to preload the rubber but prevent it crushing too far.
With age you may end up with play in the rubber but the bolt will stay tight.
Bob.
