It is currently Fri Mar 27, 2026 1:45 pm
 Post subject: lift and wheels
PostPosted: Wed Jan 02, 2008 8:55 pm
So I want to lift my 80 luv a couple inches and put some 31's on it. What do I need to do? Do they sell kits?
 Post subject: .
PostPosted: Wed Jan 02, 2008 9:10 pm
Body lift, YES
Suspension kit, none that I am aware of. best you can do there is torsion bar lift for the front and add a leaf and/or shackle for the rear.
Good how to for T bar lift
http://www.planetisuzoo.com/articles.ht ... Adjustment
FIAA: Color Guard
PostPosted: Fri Jan 18, 2008 5:37 pm
Will crankin' on the torsion bar for a couple of inches be too much stress on the suspension?
 Post subject: .
PostPosted: Fri Jan 18, 2008 6:28 pm
Mine are pretty close to 2", kind of jarring on speed bumps and pot holes, but tough enough for typical off roading.
FIAA: Color Guard
PostPosted: Sat Jan 19, 2008 1:13 am
Not sure on 31's, but you may have to modify your fenders . The tires will hit the base of fender on a tight turn. I have 215 75 R15. I think these are a stock size that go on troopers. They dont hit the fenders. But I think 31's might be a snug fit
PostPosted: Sat Jan 19, 2008 6:59 am
I have an 80 that has about 2 inches of torsion/spring lift and a 3 inch body lift and 31x10.5s still rubbed the fenders between the door and the wheel. I'd say just a little bit of trimming though would get you there with the same lift combo. It depends a lot on the wheel offset though, if they stick out farther they rub worse on the fender, but you gotta have them out far enough to clear the frame. A narrow 31 like a 9.50 might help.
