It is currently Thu Jun 25, 2026 12:09 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
PostPosted: Tue Jan 01, 2008 3:57 am
So I've been MIA for a while now, busy toiling away in the garage... although I feel not a lot has happened, but a lot has changed... :P
Here goes...
I scrapped my dovetailed and bobbed bed for toob 8) Went through and redid some old mounts and other nick-nacks...
Fresh paint...
Some Toob stuff!
Seat mounted (although it's going to have to be redone i feel due to it sitting too high...) :roll:
'Nother shot of the toob stuff.
Radiator mounting...
"I'll take 'The Rapist' for $1200 Alex..."
"That's 'Therapist' Mr. Connery"
PostPosted: Tue Jan 01, 2008 2:11 pm
Looks real nice.
Am uh... Am I missing something here though? Why're you puttin a radiator in the back?
PostPosted: Tue Jan 01, 2008 2:20 pm
in order to get a big motor in the front i asume and you have more room to work with in the engine bay
PostPosted: Tue Jan 01, 2008 8:57 pm
Ya, there isn't a whole lot of room, without cutting and tearing, to fit the radiator in the front and keep the grille and stuff in the "stock" location.
PostPosted: Wed Jan 02, 2008 10:26 pm
I thought you were making some mid-engine luv and I got really excited.
PostPosted: Fri Jan 11, 2008 1:37 am
SWEET! :D I hope to have mine at about the same stance by summer.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Fri Jan 11, 2008 9:46 am
What stance? Half done?!?! :lol: :lol: :lol:
PostPosted: Tue Jan 15, 2008 5:29 pm
I hope all done. If its only half done, I hope its the second half! :lol: :lol:
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Wed Jan 30, 2008 1:04 am
Got the Fuel cell mounted down...
The room i have to deal with, fans are going on the top side of the radiator...
PostPosted: Thu Jan 31, 2008 10:51 am
do you have any pics of it from the front thanks
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Tue Feb 05, 2008 8:21 pm
I don't have any good front pics, cus there is no grille or anything, so no real need for pics of it right now, when the bumper starts to get built, i will assure you there will be pics :wink:
but for now i leave you with some "b" squad style fab work :lol: :lol: :lol:
radiator hose connecting the bottom radiator hose to run down the frame rail...
in place for fitment, it's not lined up cus it's just resting there, i assure you it lines up perfectly :P
Fans... they came with this uber cool sticker already on them, so i had to make sure they were visable :lol:
PostPosted: Tue Feb 05, 2008 9:34 pm
what motor r u using? i'm thunking about a 4.3 later on.
PostPosted: Tue Feb 05, 2008 10:03 pm
it's a 350 TBI 8)
PostPosted: Fri Feb 15, 2008 10:14 pm
i installed a 350ci motor in my truck and put the radiator right where it belongs. course, i had to cut the firewall and set it into the cab about 4 inches. (should have gone 5" but i measured and thought i needed 3" so i went 4" to give me some extra room. turned out i could have used more!) but it all worked out in the end. i have pics of the truck but being somewhat computer illiterate, i doubt i could figure out how to post the pics here. the truck has a 27 inch lift kit overall between suspension, body lift, and tires. i want to install 44" super swampers this summer.
PostPosted: Fri Feb 15, 2008 10:42 pm
Sweet :smt118
PostPosted: Sat Feb 16, 2008 1:24 pm
Ya I didn't want to cut into the firewall as i felt it was too much work, I instead just slid the body back and made new body mounts (was going to have to do it anyways/no extra work) So it in a way pushed my front axle forward from the body giving it a way better approach angle. I could have put the radiator up front, but i wanted to keep the stock look of the front end (ie, lights/grille) plus it's a little safer from limbs and rocks in the bed :lol: .
Ya, I have a little under 4" of total lift (minus 39.5" tires of course :D ) But the top of the cab sit's at 6'-4" :egeek LOW center of gravity is what I was going for and I think i got it...sort of, it has 26" of belly clearance and about 12-13" under the diffs. 109" wheelbase i think
27" of lift!!! man that is high! ya, to post pics, go to photobucket.com make an account, upload your pics, then there will be little text boxes under the pics, copy/paste the "image/jpeg" text into a post on here and you should have a picture to show for it! :egeek
PostPosted: Sat Feb 16, 2008 3:07 pm
how do you calculate total lift? my cab is almost that tall does that mean i have close to 27" of lift????
PostPosted: Sat Feb 16, 2008 3:23 pm
no, ha ha, I calculate my lift from the stock setup of my suspension (suburban chassis) it has a 4" lift kit on it, with a leaf or two taken out to make it squat a little. I don't know what height a stock LUV sits at, but I personally guage "lift" in a couple different ways, there is overall height (fairly important to me for roll-over factor) then there is plain ol' suspension lift/body lift. Tire lift, [half the tire's diameter- centerline of axle to bottom of diff (ground clearance) ] It all depends, lol. cus ya, I personally don't have 27" of lift, my s-10 has about 12" of lift and is only a few inches taller than this truck. but that is measure from the stock height of my s-10 chassis base. but from the suburban chassis base, it was only 4" of lift to get it where it is... :egeek
it depends on how high this guys cab sits to the top of it :?:
PostPosted: Wed Feb 20, 2008 11:49 pm
dude........ your truck is beutiful :P i wish mine had a lower center of gravity and a tube bed :ebiggrin
No luv right now =(
PostPosted: Thu Feb 21, 2008 2:44 pm
Thanks!
I did a little more, work/measuring/brain storming/drinking beer, last night... Decided NOT to change my seat mounts and to keep moving forward and mount the passenger seat, I also spent a good hour, shifting the t-case in and out of gears to figure out the different combinations of gears I had, I am loving the Front Wheel Drive option :egeek That should prove to be fun. :D So now i just have to wait on the fuel stuff to come in, get my floor started and install my tranny shifter, and get my t-case shifters figured out and made. then the interior will ALMOST be done.... 5 pt harness still have to be bolted down. but i am starting to see the light at the end of the tunnel more and more...
