It is currently Tue May 26, 2026 3:31 am
PostPosted: Sun Dec 30, 2007 7:56 pm
I called Schucks and Autozone, both say they don't list it. Anyone know who carries one? Thanks!
PostPosted: Sun Dec 30, 2007 8:19 pm
I'm not sure if this is available, but I have successfully repaired one of these senders in an old Rambler. It's a bit time consuming, and there are some sensitive bits involved.
Here's a Porsche 911 article on repairing a sending unit, I haven't had the Luv unit apart, but I believe the technology is the same. It gives a good outline of what to look for.
http://www.rpm.com.au/911/html/tech_f.html
There is a guy in Montana parting out a '75, 'fbugadbug' on ebay. He may have one, not sure if he's a member here though.
You may want to put up a wanted listing in the classifieds also.
PostPosted: Sun Dec 30, 2007 8:46 pm
If it can't be fixed one solution is to by an aftermarket one with fuel gauge from jc whitney (#zx124229x) for ($24.99). It is adjustable for gas tanks from 5" to 27" deep. You will have to do minor mod work to it to get it to fit but it will.
My sending unit was not working when I bought my truck and was going to use one but I was able to fix the factory one. The float was not rubbing against the main shaft so it would not send a signal to the gauge.
PostPosted: Sun Dec 30, 2007 8:50 pm
One thing is when you use a different sending unit you can't use the factory fuel gauge. You have to use a fuel gauge with the same ohms.
The kit I talked about has its own fuel gauge.
PostPosted: Mon Dec 31, 2007 7:44 am
I have one from my old tank with gasket and screws .
PostPosted: Mon Dec 31, 2007 9:13 am
I bought the universal fuel sending unit with fuel gauge from JC Whitney also. Pretty easy to install. :lol:
PostPosted: Tue Jan 01, 2008 1:12 am
yes you can get one like for a fuel cell and if you don't need to smog put the cell it to that is what i am going to do when i get that for on mine :lol:
dangerous-toys4life
75 k-5 2x
94 king cab
Users browsing this forum: No registered users and 75 guests
