It is currently Tue May 26, 2026 5:07 am
PostPosted: Sun Dec 23, 2007 6:17 pm
Hi...Anybody know of a source for the LUV window channel and 'anti-rain' rubber that acts as a squeege against the glass?? Sorry...I really don't know what that piece is called. Mine have fallen apart and the chrome edged rubber wiper is shot. My windows rattle in the channels and plenty of cold air enters when I'm driving the little baby around. I see that JC Whitney has quite a selection of channel...maybe someone has purchased the corrct pieces and has the correct Whiitney stock number. Thanks for your help. DON.
PostPosted: Mon Dec 24, 2007 11:33 pm
Go to http://www.restorationspecialties.com You have to call them to order, but they have door seal and window channel for LUVS. I'm not sure if they have the squeegee piece you are talking about, but talk to them about it. I'll bet they find a good close match.
 Post subject: Window channel
PostPosted: Wed Dec 26, 2007 6:22 pm
Thanks rondog...I'll look them up. Don H.
PostPosted: Fri Dec 28, 2007 11:37 am
i think the window squeegee thing is actually called "door belt" or "window belt". let us know if you find something that works I have been staring at mine also that need fixing.
Current Fleet
pics
PostPosted: Fri Dec 28, 2007 2:11 pm
PITA Old Fart
Ditto...mine looks pretty bad.
PostPosted: Fri Dec 28, 2007 6:03 pm
they are just stapled on to the metal, i was thinking any newer car or truck with good soft ones would work just have never took the time to try... just an idea to think about
PostPosted: Sat Jan 26, 2008 10:38 pm
Just a word of caution: The newer Luvs are different from the older ones. I don't know when they changed, probably when they removed the wing windows.
On the inside, my 75 (wing windows) has that fuzzy stuff that looks like a brush. On my 79 (no wing windows), it's rubber. The rubber is thicker across the bottom. If you try to put it on an older one, like I did, the window won't crank all the way up.
Same for the outside. They look the same, but the 79 has a lip on the bottom. When I put some on the 75, it kept the window from cranking all the way up. I had to carefully removed the lip with a box cutter to make it work.
I've bought from restoration specialties before and, other than slow delivery, it worked out well.
You went there in that?!?!
PostPosted: Sat Sep 19, 2009 2:33 pm
Any luck on the finding any window belt / window squeegee. I'm in need of some.
PostPosted: Tue Sep 22, 2009 6:24 pm
in the mustang world they are called dew wipes, maybe that will help with finding them
anyone tried making one themselves?...i havent looked at one, so it may be more work that i think it is
just your average bagged v8 mini truck
