It is currently Sun Apr 12, 2026 8:26 pm
 Post subject: bad back firing
PostPosted: Mon Dec 03, 2007 1:30 am
ok i had just bought my first truck my 80 Chevy luv 4x4 and i am having problems with th stock 1.8L back firing really bad so i did the timing and it was off at 14% so i fixed it helped a little bit but it still did it when shifting between 3rd and 4th. then after a little 4 wheeling trip it started to spudder so i turn it off then later i went to drive it started and the back fired when i hit the gas like a cherry bomb and would only hit for a min then die and die if i gave it gas and now it cranks and spudders trying to start need help asap please. plus hate to see it go cause i cant get it running because i really luv this truck
PostPosted: Mon Dec 03, 2007 4:44 am
Check your points
PostPosted: Tue Dec 04, 2007 10:07 pm
THANKS TJ it runs alot better with the new points in it. Any recomondations on a exhaust, mine is in need of a new one.
 Post subject: .
PostPosted: Tue Dec 04, 2007 10:25 pm
Funny you should mention exhaust. Check to see if you have a leak around the exhaust manifold or the EGR tubing leading into it. Mine had some of the worst backfiring I've ever seen after the tube split a little on the way home.
I was limping down the streets litteraly apologizing to the neighbors 8O
FIAA: Color Guard
PostPosted: Wed Dec 05, 2007 11:51 pm
Id go with a free flowing muffler and try to keep the stock diameter exhaust piping.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Dec 06, 2007 8:42 pm
mine also backfires and it got loader and louder and what do you no the exhaust droped from the manafold so i welded it and i to need a new exhuast system but for now i welded it back to the manafold
My ride pics http://viewmorepics.myspace.com/index.c ... mId=829085
PostPosted: Mon Feb 04, 2008 12:28 am
Why would the points affect backfireing? After reading that I'm going to change mine since mine backfires from 3rd to 4th but whats the correct point gap for an '80 1.8?
PostPosted: Mon Feb 04, 2008 9:51 am
A hole in the exhaust will make it back fire.
So will a burnt valve, but this is unlikley on a crossflow motor.
Bob.
Users browsing this forum: No registered users and 87 guests
