It is currently Mon Jun 08, 2026 6:45 pm
PostPosted: Sun Nov 25, 2007 3:59 pm
I went to start my Luv today and the solenoid in the starter keep turning over, I shut the key, still keep going. I thought maybe the switch was a little sticky, so I unpluged the switched, it still keep going! I had to run into the garage and get a wrench to get one of the battery cables to come off. :lol:
I've had this happen on a Nissan I use to own. Does then mean I'm going to replace the starter? In the past I rapped the side of starter and it worked for a little bit.
PostPosted: Sun Nov 25, 2007 6:45 pm
Sounds like a bad soleniod. If it didn't damage the starter, or the flywheel just replace the soleniod.
PostPosted: Sun Nov 25, 2007 7:13 pm
I had the battery to solenoid stud back out on my solenoid, caused all sorts of weirdness with the truck. I second Johnboy's comment, you could probably get away with just changing out the solenoid.
http://www.rockauto.com lists the solenoid for $20.79 (AIRTEX Part # 1M1060). I'd guess NAPA runs about the same price...
PostPosted: Mon Nov 26, 2007 12:01 am
i had a wire ground out and it made my starter stay on so i took the cable off then looked for a min or two and found the wire taped them will up good and no problem :lol:
dangerous-toys4life
75 k-5 2x
94 king cab
 Post subject: solenoid replacment
PostPosted: Tue Nov 27, 2007 12:26 am
Does the solenoid come off the starter? I've heard in some cases its built in and not removeable. I should check my Haynes manual, but sometimes they dont have details like this in there.
PostPosted: Tue Nov 27, 2007 12:41 am
Factory manual refers to the solenoid as 'magnetic switch'.
Comes off with two bolts...
Here's the guts...
This is from a Series 10 manual, hope it helps...
PostPosted: Tue Dec 04, 2007 12:03 am
I work for a starter and alternator rebuilding business. Yes, a stuck starter solenoid will cause this. What happens though, is LOW voltage makes the solenoid plunger arc weld itself to the contacts. If you do not fix the low voltage problem, it will happen again with a new solenoid. Probably in only a few days. Get your charging system checked by someone like us, or someone specializing in auto electric issues. NOT your local parts store, they are too often clueless.
 Post subject: Low Voltage
PostPosted: Thu Dec 06, 2007 12:07 am
Thanks for the info 75Guy. So if there is a low voltage problem, does that mean it just the altenator, or can it be other issues too. I did change my voltage regulator the month before this.
PostPosted: Thu Feb 14, 2008 11:42 pm
I found out my problem why the regulator fuse was blowing. I had an exhaust hanger replaced, near that hanger is the fuel pump. The wires got to close to the pipe and melted the insulation. When the truck warmed up, it grounded out and blew the fuse.
Also I'm going to replace my starter solenoid. Based on the incident of my motor turning over for a couple of minues continuesly, should I replace the stater too? I bought the starter a couple of years ago, and I only run th truck on weekends.
Users browsing this forum: No registered users and 55 guests
