It is currently Sun Dec 21, 2025 9:01 pm
PostPosted: Sat Nov 03, 2007 7:01 pm
is there any places i should add crossmembers to make the truck more ridged so i can prevent the frame from twisting? the crossmember behind the transmission crossmember to the one over the rear diff. would that be a good place add crossmembers to? any help would be great
PostPosted: Sat Nov 03, 2007 8:33 pm
Other than a cage i don't think theres much more you can do, these frames are already a box design which are pretty darn stout.
PostPosted: Sat Nov 03, 2007 9:29 pm
A bit of re-enforcement on the fame (not a cross-member, more like a patch) on the bits right behind the cab would help a bit, it has been noted as the weakest point by some local people that have crushed these trucks a time or two, he said that's the first place all of them have bent, me and my dad have also seen them rust out there first before other areas....
PostPosted: Sun Nov 04, 2007 2:00 am
If you run ladder bars with sliders(leaf spring) or coil overs you will be putting in one more cross member just behind the cab to mont the ladder bars. I used the 2X3 setup on mine and it is almost strait down from the back of the cab i will check and see if i have any picks.
PostPosted: Sun Nov 04, 2007 11:21 am
if any of you have pictures i can see the would be awesome. and thanks for the help. so the crossmember behind the cab that c crossmember is the weak point? should i box that in?
PostPosted: Fri Nov 09, 2007 5:40 pm
i dont see a need for any other reinforcments. i have a full cage and can suport all for corners with 3 jack stands. 2 in the rear and 1 in the front on either side and the other side stays even. now thats pretty firm if you ask me.
9.75 @138 496
luv to race
PostPosted: Fri Nov 09, 2007 6:40 pm
im curious what your goal is for the truck
PostPosted: Fri Nov 09, 2007 7:57 pm
my goal is to have a daily driver but a weekend terror at the strip. i would also like to make it an auto cross rig later. those are my goals.
PostPosted: Fri Nov 09, 2007 10:58 pm
The frame area, not the cross member, however the frame already is very strong, but that's the area that tends to rust out first if the frame has a major scale problem.
PostPosted: Fri Nov 09, 2007 11:06 pm
Idon't know about autocross, but I, as well as several of my friends, have had several Luv's in the tens with nothing more than slapper bars and 9 inch slicks. This was with 350 and 400 sbc's with a shot of NOS years ago. Unless you have a rust problem like Finalman mentioned, I'd just add the 12 point cage and forget about it...
PostPosted: Sat Nov 10, 2007 10:21 am
If you plan on autocross, you better think about cutting the firewall out and moving your motor back about 6 inches,if not your in for alot of cone eating!You want 50/50 weight balance for autocross,and you wont be close where the motor is sitting now.
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Mon Nov 12, 2007 9:46 pm
Autocross is a different type of racing. The setup is a whole different thing than street or drag racing. You will need to look at the SCCA web site and see what class your truck would run. They have added a few street classes so the F&F style cars can run, as they did not fit any class.
85 VW Scirocco DSP regional champ '90-'93
I still have it. It would now be run as FSP (Street Prepared)
It has not been a street driven car since it went to a xcross car in '89
It will kick the shit out of VR6 cars in the club I was in, but most were just peoples cars... With FWD cars you are getting it when you are up on "three wheels" in the corners. Outside rear wheel comes off the ground. Boy it sure was a kick in the butt.
PostPosted: Tue Nov 13, 2007 7:39 am
I had a 82 rx7 I ran autocross and hillclimbs with,ran in CSP.Still have it also,but the body/chassis is going bye-bye soon to free up the motor and tranny for a truck swap! :)
[color=#FF8000]
PostPosted: Tue Nov 13, 2007 5:57 pm
I always liked the little Mazda Truck that came with a rotary in it. Most have gone to that rust bucket in the sky.
I saw a big block Camaro run. When our club rented a track for a day, one of the owners brought out his Viper SP car.... My son got a ride with him.... He was on it before he got his tires warmed up.... Looked like a tornado. My son must have set a record high on his puckamonator 8O (butt pucker gauge). It was very fast
Post related. Suspension is where your best buck can be spent.
