It is currently Thu Mar 26, 2026 11:39 pm
 Post subject: 4 lug front bolt pattern
PostPosted: Fri Nov 02, 2007 5:18 am
i know it's most likely been discussed on here but i can't find it, can you redrill the front to a 4 lug pattern? i saw a luv at the track a couple of weekends ago with this set up and was wonder is it easier than the 5 lug redrill and is this the late 80 early 90 mustang pattern?
PostPosted: Fri Nov 02, 2007 6:42 am
most likely they had pinto spindles and rotors on it.We use pinto spindles all the time on dirt modifieds,but we use a aftermarket grenada rotor that is has a dual 5 bolt pattern.
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Fri Nov 02, 2007 6:47 am
mad dog how easy of a mod is this.
PostPosted: Fri Nov 02, 2007 8:18 am
I haven't had a chance to look at his truck , but Greg Bagwell ( easy luv'in ) who was the 5.80 king has a pinto/mustang II under his truck .
PostPosted: Fri Nov 02, 2007 7:24 pm
the swap is easy,we use screw in ball joints,(weld in ball joint holders)the swap rotors bolt right up to the spindles,bolt on adapter for using metric calipers on pinto spindles.depending on what ball joint size we sometimes ream the spindles out to run the bigger ball joint.Parts are pretty cheap,and you can even get aftermarket pinto spindles if you cant find any in the junkyard!
[color=#FF8000]
 Post subject: truck
PostPosted: Fri Nov 02, 2007 7:35 pm
Hey CT NICE TRUCK!
PostPosted: Sat Nov 03, 2007 8:30 pm
i wish i coud say it was mine but i cannot, it was at baytown for the texas vs the world and S&S race.
