It is currently Mon Jun 08, 2026 7:54 pm
 Post subject: whats this
PostPosted: Sat Oct 27, 2007 2:50 pm
i hate to ask but i cant find it in my book and i dont know what it would be called... it looks as if oil is coming from it but like i said i dont know what it is or if it needs to have a plug in it or whats going on... :?
EDIT: i guess pics would help :lol:
'79 luv near stock
'80 luv "sold to another luv owner"
PostPosted: Sat Oct 27, 2007 3:23 pm
if thats the one i think its just a hole maybe used in the manufacturing of the block mine has that and nothing goes there, if its the one i am thinking of
PostPosted: Sat Oct 27, 2007 9:38 pm
It's off of an airplane - you don't see it on one do ya? :lol:
J/K..
Seriously though ...it's just a casting hole that was probably used to lift the block so they could move it around at the factory. Nuttin' to worry about.
PostPosted: Sun Oct 28, 2007 8:45 am
thanks you guys for the responce :D
'79 luv near stock
 Post subject: Re: whats this
PostPosted: Sun Oct 28, 2007 9:47 am
Looks to me like your oil is coming from a long way further up.
Id say the valve cover.
You need to book it in for a good degrease.
Bob.
PostPosted: Sun Oct 28, 2007 7:13 pm
no its not coming from the valve cover i just replaced the gasket and not even a week ago i cleaned that side of the engine :? i do think i have a bad head gasket because i have a pretty good trail of antifreeze coming down the side of the block, i pulled the exhaust to look for a crack in the block and dident see one, but i did notice some white crusty sort of build up where the head meets the block... so i guess now i just got to chase down the oil leak and replace a head gasket, i just hope i dont run into problems or find any more installing the new gasket
'79 luv near stock
PostPosted: Mon Oct 29, 2007 6:01 am
It's better to do it now before it over heats out in the middle of nowhere and you risk the chance of possibly warping the head. Been there - done that. :(
Besides, while you have the head off, you can clean all of the carbon/crust off of your piston tops and your valves. Plus you can clean up your exhaust and intake manifolds while they are off. :wink:
PostPosted: Tue Oct 30, 2007 2:15 pm
Yep im for sooner rather than later.
And it still could be the valve cover gasket leaking. It s only tin and could be warped.
Hence why i suggested to wash it. Once its clean you can spot the leak easily.
Bob.
Users browsing this forum: No registered users and 50 guests
