It is currently Mon May 25, 2026 2:32 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 Post subject: trany ? buick 231 v6
PostPosted: Thu Oct 25, 2007 3:49 pm
i found a 231 v6 rebuilt for $75 and was wondering what if any 5spd will bolt to it? anyone know
PostPosted: Thu Oct 25, 2007 6:59 pm
A t-5 will bolt up if you get the BOP bellhousing. There have been a few on E-Bay or you can look for the Monza clones like the Buick Skyhawk and some of these had a saginaw 5 spd.
I have one in my truck but i am not ready for the auto for drag racing yet.
Look on E-Bay under Buick parts.
PostPosted: Thu Oct 25, 2007 8:12 pm
thanks, i was thinking the monza was the same but wasnt sure
PostPosted: Thu Oct 25, 2007 10:03 pm
I have a 5 speed out of a v-6 camaro for you if you decide to get the v-6
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Thu Oct 25, 2007 10:10 pm
and the s10 has the 5 speed with the v6
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu Oct 25, 2007 11:08 pm
do you know for sure the chevy 5spd will bolt to it... did some looking to night and somewhere it said buick and chevy had different bolt pattern but i only saw that at one place the others didn't mention it so i'm not sure
PostPosted: Thu Oct 25, 2007 11:27 pm
the bellhousings are different pattern,but i think tranny bolt pattern is the same?
[color=#FF8000]
PostPosted: Thu Oct 25, 2007 11:30 pm
ok maybe thats what they where talking about.... hay tilted how do you like yours and how much power do they have? what hp can i get out of one with out turbo, is 200hp good to shoot for?
PostPosted: Fri Oct 26, 2007 6:12 am
200HP is a no brainer as you can get that easily without the turbo,you will be in the 300+ range for a easy to drive motor that only weighs 400lbs so now you will have good power and it will handle to on the street.
The bellhousings are different but use the same trans bolt pattern.
PostPosted: Fri Oct 26, 2007 11:52 am
There was one here a while back on eBay with the chevy V6 in it. They arent a common motor down here.
We had the Buick derrived 3.8L V6 in one of our local cars and they are popular to swap into all sorts of things. Mostly with the TH700R or the T5 if you can find a manual one.
Bob.
PostPosted: Fri Oct 26, 2007 12:26 pm
As the commercial says, "I could of had a V8", Its not bad but after I got my SS S10 with the 4.3 Vortec, my LUV seems pretty slow now. Plus having a turbo 350 with the stock rearend, I can get to about 60-65 pretty quick but then it sounds like it wants to blow up because the RPMs are so high. Should be better with a 700R4 (which I dont think they had at the time I put mine it) but I will be adding 2 more cylinders like I should have in the first place. :x
PostPosted: Fri Oct 26, 2007 6:02 pm
There are 3 V-6. The Buick, a narrow 60 degree engine and the Chevy which is a V8 with out two cylinders. You know which one you are talking about, but be sure about other parts. BOP parts fit the 231. Different trannys may work. I don't know other than the ones that came with the engine.
PostPosted: Fri Oct 26, 2007 6:04 pm
Well 4 if you count even fire and odd fire 231's but that is in the engine only... We won't get into the old, BIG GMC V-6's
8)
PostPosted: Fri Oct 26, 2007 8:25 pm
not sure even what year the motor is yet... ill go see saturday and run the numbers... the luv was for sale locally but ended in the wrecking yard and they don know its been rebuilt so they said they would sell it to me as a core
PostPosted: Sat Oct 27, 2007 3:41 pm
found out its a 77/78 could be odd fire (77 was change over to even) but cant tell.. here are some pics of the motor ill get ,the step side bed and a good dash ( the tape is to hold it and keep it from cracking in the weak spots) to make a fiberglass copy off this coming summer
check out these motor mounts, 1/8 flat steel welded under the frame, is it just me or is that crazy
not bad for $10, i think this will work for a fiberglass mold
anyone know what rear this is
PostPosted: Sat Oct 27, 2007 4:26 pm
Is the motor mounted in the truck in that first pic?? Looks like it sits about a 6" lower and 6" forward more than mine. Which is strange as I cant get my tranny out without pulling the motor as the top 2 bellhousing bolts are right against the firewall , my fan is less than a 1/2 inch from my radiator, my air cleaner barely fits under the shut hood and my headers are about an inch from dragging on the ground. Looks like you have all kinds of room there. 8O
PostPosted: Sat Oct 27, 2007 6:17 pm
its mounted but if he ever hit a bump it would od ruined the pan... the mounts he made are on the bottom of the frame and go straight across... like you said it sit way low, there its about 4 inches from trany to body
here is another see how it sits
 Post subject: rearend
PostPosted: Sun Oct 28, 2007 12:58 am
the rearend looks like a s-10 rearend i have one in my s-10 frame that i am building for my luv
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sun Oct 28, 2007 1:10 am
ok thanks
PostPosted: Mon Oct 29, 2007 8:17 am
Check the engine over closely as it looks like it could also be a 3.8 Chevy motor witch is allot like the Buick motor and if it is it will have the chevy bellhousing bolt pattern. Also be sure you get the dist.
