It is currently Mon Feb 02, 2026 10:24 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Mon Oct 22, 2007 2:22 am
nup you dont use the gasket for the head.
If its a 1600 or 1800 head on a 2L block you use the 2L head gasket as the boreholes need to be that big.
You wouldnt use a 2L head on an 1800 motor as the compression would be pretty low.
Bob.
PostPosted: Mon Oct 22, 2007 3:37 pm
Well turns out it was the headgasket, even with it being brand new...
She runs now, very slow, but runs nonetheless.
Btw, instead of opening a new thread I'll just ask it in here... Would a Jeep 4.2L straight six fit in my luv?
PostPosted: Mon Oct 22, 2007 9:59 pm
Not without a lot of mods, since the stock transmission won't bolt up to it.
Neither will the stock driveline, so IMHO you'd be asking for a real large problem for youself just to make it all work.
Although the stock Luv engine isn't the most powerful on the block...you can do a lot of stuff to boost up your hp/torque.
Take a look at this thread: http://forums.luvtruck.com/viewtopic.php?t=10702
PostPosted: Tue Oct 23, 2007 6:44 pm
Nope it's way to long, thats not saying you can't put a dog house in the fire wall but it's just not practical.
PostPosted: Tue Oct 23, 2007 9:33 pm
Yea, I figured it wouldn't fit, twas just a great deal and I really wanted it.
Eh.
PostPosted: Wed Oct 24, 2007 7:18 am
:idea: I have a 79 4X4 that i am thinking of putting a S-10 2.8 with a overdrive auto into it other then the usual motor mount fabbing all i would have to do is change the transfer case to a full size one so the front drive line will mate up.
Yeah i know that thes motors were slugs in the S-10 but the LUV is so much lighter that it would a good swap plus it wont over power the axles and would get terrific fuel milage. And there are allot of them so they are cheap.
PostPosted: Wed Oct 24, 2007 11:38 am
There is a T-bird turbo coupe engine/5 speed for sale here locally. This seems like a swap that might be interesting, it seems like it should fit. I bet it would be fun in a Luv, 190 HP in stock form... :D
http://eugene.craigslist.org/pts/451883817.html
PostPosted: Thu Oct 25, 2007 9:51 pm
Impulse turbo would be a whole lot easier, about the same HP but bolts striaght in if you get the right mounts.
Bob.
