It is currently Mon May 25, 2026 7:24 am
 Post subject: disc brake rear
PostPosted: Thu Sep 27, 2007 5:46 pm
Has anyone done a disc brake swap on the stock rearend? I have my truck completely bare to the frame and I'm going to do a swap on the rear to dics. I did a swap on my toyota and my k5 blazer it wasn't much work. Just want to see if anyone else has done one.
Thanks,
Craig
PostPosted: Thu Oct 04, 2007 10:16 pm
that sould help out i am thinking about doing that too make my little 77 stop faster and easyer
PostPosted: Thu Oct 04, 2007 11:40 pm
I don't know either but wish I did as well, because sometime this weekend I'll be doing a brake job on my 80 4x4 Daily Driver, If you figure it out let me know maybe I'll do the same change your trying to do....good luck :) T
PostPosted: Fri Oct 05, 2007 5:28 am
I'll let you know and keep everyone posted.
Craig
PostPosted: Fri Oct 05, 2007 8:05 pm
Doesnt aerospace make a kit? I was/ am planning on using the front conversion as well as the rear from them.
PostPosted: Fri Oct 05, 2007 11:01 pm
Swap Specialist Mod
later model troopers and pups have disc brake rears. ive seen a trooper rotor and caliper used on a datsun 620.
PostPosted: Sat Oct 06, 2007 7:38 am
How about a S-10 rear wiyh 82-92 F-body disc. brakes it would be a bolt on deal and you would have a better choice of gears as well as a stronger rear end, oh and you can get a posi too.
PostPosted: Sun Oct 07, 2007 11:05 am
Thats the big question is the s-10 rear is better? Might be might not. The rearend in my truck has custom machined fullsize moser axles that are resplined and sized to fit the luv rear. This rearend has been under the truck for 8 yrs and never broke a axle. With the 383 and a set of drag radials. The truck was a street/strip setup when my father owner it. I personaly don't want to go to 5-lug because it takes some of the originality away from the truck and i'm going to do a disc brake setup on the stock rear.
Thanks,
Craig
Users browsing this forum: Bing [Bot] and 19 guests
