It is currently Mon Jun 08, 2026 4:12 pm
PostPosted: Tue Oct 02, 2007 3:01 pm
What's involved in swapping the single headlight setup onto an older cab?
PostPosted: Thu Oct 04, 2007 10:18 pm
why dont like the older 2 headlight ones
PostPosted: Fri Oct 05, 2007 4:02 am
It's not so much about looks, but more about lighting quality and the parts I have to work with.
PostPosted: Fri Oct 05, 2007 5:30 am
The core support is diffrent and it requires cutting the single to adapt to the dual.
Craig
PostPosted: Sat Oct 06, 2007 5:16 am
Australian LUV Guru
I have changed my singles in my 1980 to duels, i found there was no difference in the core support. Image Image
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sat Oct 06, 2007 10:10 pm
OzLuv - Man that is one clean truck! That photo of the front with one headlight swapped is awesome...
I had questions about the front fenders, but your pics pretty much cleared it all up.
PostPosted: Mon Oct 08, 2007 6:00 am
currently doin mine atm got to make up all new mounts man theres fair bit of mucking around in it but freshen's up the front nicly
 Post subject: core
PostPosted: Mon Oct 08, 2007 12:12 pm
The single truck that got one dual setup off had a additional cut out to accept the light and wiring. Don't know but that one was definatly diffrent.
 Post subject: Re: core
PostPosted: Thu Oct 11, 2007 5:50 am
Australian LUV Guru
Trucks with factory fitted duel lights have a hole for the extra lights wiring, factory single light trucks dont have this hole. This problem can be overcome by using a side entrace wired type plug, fit the plug to light then install the light into its buket.
 Post subject: Single head lights
PostPosted: Sat Oct 13, 2007 7:04 pm
I'm just bought a luv with dual head lights and i would like to change it to single can you help.
PostPosted: Sun Oct 14, 2007 12:33 am
So, its somewhat of a pain to go from single to dual?
I've always wanted to do that and I think I might sometime soon...
PostPosted: Sun Oct 14, 2007 4:23 am
Australian LUV Guru
Its a straight forward easy swap from single to duel or vice versa, the only thing that can be painful is the wiring.
PostPosted: Tue Oct 16, 2007 3:25 pm
My truck had the quad lights when i got it but i went to the duels to clean it up .It also now sports the bumper again and a silver grill.
