It is currently Fri Mar 27, 2026 12:20 am
 Post subject: rear end
PostPosted: Sat Sep 08, 2007 12:53 pm
Does anyone know off hand if Isuzu offered a rear end with dics brakes? I just read a article on a older Isuzu that the owner installed a dics brake rear.
Thanks,
Craig
 Post subject: rear
PostPosted: Sat Sep 08, 2007 12:55 pm
never mind the trooper Had the dics rear. Does anyone know the width of the rear and will it swap?
PostPosted: Tue Sep 11, 2007 5:34 pm
Any Aussie friends know?
Craig
PostPosted: Tue Sep 11, 2007 6:21 pm
My wife had a Rodeo that had discs on the rear .
PostPosted: Tue Sep 11, 2007 6:53 pm
I wonder if the rear end is the same width? they made some years with Disc brake and a 44 center section. I would like to know if anyone has one and If the Width will match. The rear 44 would be easy to get gear sets for.
Craig
PostPosted: Tue Sep 11, 2007 7:22 pm
It was 6 lug 44 center and disc brake
PostPosted: Tue Sep 11, 2007 10:46 pm
I rekon i just read something about the 44 centre. Its not a std gear set and its not a straight swap to put any old dana gears in it. The crown wheel is heaps thicker and the pinion takes a dana 60 series size yolk.
Theres two types of disc setups on the 220mm diff,
Disc with hand brake intergrated into the caliper. These are a 2 inches wider than your Luv/pup rear end.
Larger disc with a small drum for a e brake inside the disc. This is a better setup but its wider again over the above and in the later model V6 Trooper.
The trooper went to a 2 inch wider track in 87 but still with the 197mm diff and drums.
Bob
PostPosted: Wed Sep 19, 2007 6:59 pm
Not sure about disc rears but my 80 had a Isuzu rear with drums and it bolt right in
PostPosted: Wed Sep 19, 2007 8:36 pm
i got one out of a 89 pup and i had to cut the axle pads off and move them out 1/2 "
dangerous-toys4life
75 k-5 2x
94 king cab
 Post subject: rearends
PostPosted: Thu Sep 20, 2007 5:52 am
Bud do you have pictures of you rear? They say that the disc setup off the troopers and amigo will bolt right on to the pups. Just wanted to see if you had any visual help.
Thanks,
Craig
PostPosted: Thu Sep 20, 2007 12:29 pm
PITA Old Fart
My...aren't we popular today? :lol:
PostPosted: Thu Sep 20, 2007 12:49 pm
well i never thought this site would be like that :cry: lol i have the rearend siting in the back of the luv after i got it in the truck i needed to drive it and did not have the time or $ to get the drive line done so i put the old one back in to drive it so i am know working on a s-10 frame witch i need to take some pics i will have them up bi this weekend and here is a pic of my rear
Image lol
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu Sep 20, 2007 2:10 pm
That is a bushy rear. :fist:
PostPosted: Thu Sep 20, 2007 11:18 pm
PITA Old Fart
Lmao! :lol:
