It is currently Sun Jul 20, 2025 8:52 am
 Post subject: highest compression
PostPosted: Wed Aug 08, 2007 6:23 pm
whats the highest compression youve guys seen in a 1.8?
I think it says 170 in the book, that seems like a lot. I just did a rebuild im only gettin 135, up from 90 though.
PostPosted: Wed Aug 08, 2007 7:41 pm
To get the correct compression you should remove all spark plugs, have a fully charged battery and have the carb at wide open throttle.
PostPosted: Wed Aug 08, 2007 8:19 pm
in addition to that.... its considered normal if the lowest compression reading is at least 75% of the highest reading.
I would consider 135 normal...170 seems pretty high to me for such an older engine...
but I am no 1.8 guru tho
PostPosted: Wed Aug 15, 2007 10:40 am
i just did a comp test and the lowest i got is 178 the highest is 183 the two inside pistons were in 178 and i think 179 the outside was like 182 183
PostPosted: Wed Aug 15, 2007 12:42 pm
I would consider 120-140 normal. If yours is that high it would only be---the head has been planed, much carbon build up, or your gauge is lying to you.
PostPosted: Wed Aug 15, 2007 5:13 pm
i neve thought about that, the motor was just rebuilt so i could see the head being shaved. anyway its all good cuz all i understand is mo power lol
PostPosted: Thu Aug 16, 2007 6:24 pm
thats really high, but good for you, more power in the luv the better!!! 8)
1979 4x4 LUV, rebuilt 1.8 and 27" bald tires
PostPosted: Fri Aug 17, 2007 3:24 pm
My 80 tests out to 195/200 across all four cylinders, but it looks like a G200 with a G180 head on it.
One other bit to make sure of when you run a compression test is that the valves should be adjusted right. That can bring your numbers way down too.
Users browsing this forum: Bing [Bot] and 42 guests
