It is currently Fri Apr 10, 2026 6:59 am
 Post subject: Carb Question
PostPosted: Tue Jul 31, 2007 1:01 pm
Now, if I were to buy the carb below, since its brand new and whatnot, but it doesn't come with an adaptor, where can I buy an adaptor?
http://cgi.ebay.com/ebaymotors/Holley-C ... enameZWDVW
PostPosted: Tue Jul 31, 2007 1:24 pm
From another post on this subject, ctman likes the 250 :D The adapters run about $30. The full install redline kit is about $90...
nukeday wrote:
Here's a link for just the adapters, you'd need to fab your own throttle linkage setup...
http://www.jameng.com/prices/index.phtml#99004.333
From another thread, ctmandu:
"any one of these will work, the first one is what is on mine
http://www.jameng.com/products/images/99004.300.jpg
this would be the best
http://www.jameng.com/products/images/99004.250.jpg "
The redline installation kit:
79-LUV'r wrote:
You might also consider:
http://cgi.ebay.com/ebaymotors/Weber-32-36-DGAV-33B1-Toyota-Carburetor-Carb-Datsun-NR_W0QQitemZ180143780875QQihZ008QQcategoryZ33550QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Used-32-36-Weber-Carb-could-fit-dune-buggy-VW-Porsche_W0QQitemZ230156071120QQihZ013QQcategoryZ33550QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
PostPosted: Tue Jul 31, 2007 3:30 pm
Thoses holley weber carbs won't work on the later years luvs with the carb on the passenger side, but if you have a early luv with the carb on the driver side it might. I don't know to much about the early years luv.
PostPosted: Tue Jul 31, 2007 3:35 pm
1980.
PostPosted: Tue Jul 31, 2007 7:24 pm
That's a lot of carb. for a stock eng. That is not a progressive carb. Both those barrels feed at all times. It is not a mileage carb and just might be too much.
PostPosted: Tue Jul 31, 2007 11:47 pm
Well, what carb would you suggest? I just like that because its cheap, but I don't need power. Got a cheap carb with good gas mileage?
PostPosted: Wed Aug 01, 2007 8:42 am
I asked a the carb genie here at the office-he said Weber 32/36 DGEV. Just looked it up-found 'em for around 360bucks 8O
-Model K662
PostPosted: Wed Aug 01, 2007 9:07 am
also the DGEC can be found for around $300. It is a better version of stock. It runs on the one barrel for normal driving and opens the secondary barrel when you floor it.
http://stores.ebay.com/Net-Parts-Express
This place sold me one for $300 -free shipping.
 Post subject: .
PostPosted: Wed Aug 01, 2007 9:45 am
There's also a 34/34 DGEC progressive
kit, comes with adapter, throttle linkage.
http://www.theape.com/newmodel.html
FIAA: Color Guard
PostPosted: Wed Aug 01, 2007 9:46 pm
How much is that Luv'r?
nukeday wrote:
Did you edit that in there? Or I musta just missed that, will both of those work? I'm pretty sure my carb is on the passenger side....
And also, does that second one come with the adaptor needed to hook it right up?
 Post subject: .
PostPosted: Wed Aug 01, 2007 10:13 pm
The one I listed, from theape.com, I gave $289 for it free ship.
FIAA: Color Guard
 Post subject: Re: .
PostPosted: Wed Aug 01, 2007 10:59 pm
Man, I was really hoping to get it cheaper. Will the ones on ebay that nuke posted earlier work?
PostPosted: Wed Aug 01, 2007 11:06 pm
PITA Old Fart
You can pick a weber 32/36 up cheap used on ebay, and then get a cheap complete rebuild kit on ebay too. A lot of them even come with an adapter plate and the air cleaner.
Just do a search for weber carbs and you should find a bunch, and if not keep trying every day because they are always on there. Rebuilding one is pretty simple.
I've got a rebuilt 32/36, and a rebuilt 38/38 that I'm using, plus 3 others I have for spare parts - and I never spent over $75.00 for any of them including shipping.
You can download a file that has ever bit of info on every weber ever made here: http://www.luvtruck.com/pdf/Weber_files.exe
Just right click on it and save it to download it, then double click on it and it will unzip into a folder full of .pdf files that you can view in adobe reader.
PostPosted: Wed Aug 01, 2007 11:34 pm
This carb should fit your truck with a $30 adapter from JAM and some creative throttle cable mounting. Not sure which adapter the second one has, but odds are it's for an import.
Taz is pretty much on track here, you should be able to do a carb, carb kit, adapter and throttle mount for under $100. Take a quick read through the pdf taz linked to. There are a couple of wear spots to be aware of on the weber. They often come up on craigslist too, a lot of time freshly pulled from a toyota or datsun. Usually they run about $125-150 on CL. You might even get lucky and not have to kit the used carb at all.
PostPosted: Thu Aug 02, 2007 12:34 am
Which adaptor from JAM would I need?
Also, in the manuel it says for my LUV I need a 32/32. Should I get a 32/32 or one of the 32/36's?
And, no matter what, I need a DGV series, not a DFV series, right?
PostPosted: Thu Aug 02, 2007 3:27 am
PITA Old Fart
The 32/36 weber carb is best for a stock G180. That way you get good gas mileage when you are driving normal and performance when you want/need it. And the DGV series is the best choice. Whether you get one with a manual choke or electric (one wire) choke is entirely up to your personal preference. Both are good carbs.
For a G200 (either the stock G200 Pup engine or the higher performance Impulse 1.9 G200 block) you can run a Weber 38/38. But it doesn't work out well for a stock G180 because it's just too much carb due to the G180's smaller valves.
PostPosted: Thu Aug 02, 2007 11:35 am
From earlier in this thread, any of these three would work:
The JAM pn's are listed in the links, or you can call them. It's sort of a one man shop, but he's pretty responsive. I accidentally called him after hours and he answered on his cell. He asked me to call back during business hours to place an order...
PostPosted: Thu Aug 02, 2007 2:26 pm
Out of sheer curiousity, would it upp my hp at all?
Sorry about that, I really didn't understand the first time. Thanks for all the help though.
PostPosted: Fri Aug 03, 2007 12:38 am
PITA Old Fart
I'm not sure I understand your question...but switching to a weber 32/36 from a stock Hitachi will not only increase your engine's hp a bit, but will increase the engine's performance as well. Simply put - it's a better carb by far. Proof of that is the fact that most people notice an improvement in gas milage after they bolt on the weber as well.
PostPosted: Fri Aug 03, 2007 1:14 pm
Thats what I was wondering. Thanks all.
Users browsing this forum: No registered users and 76 guests
