It is currently Mon Jun 08, 2026 6:35 pm
 Post subject: Please Help!
PostPosted: Sun Jul 29, 2007 3:58 pm
Hey everyone here is my problem:
My truck's a 75 and I bought it for 230 bucks a month ago and it ran great but two weeks ago I went out to the truck and turned the key and nothing happened. I think it clicked once, but no turning over or anything. I kept jimmying with the ignition for awhile and it started. Since then i cant get it to do anything! Turning the key has no affect on anything! My left blinker works, but doesnt flash, and my headlights wont work. its weird. I hate electrical and i dont understand it too well, but here's what ive done
-replaced starter
-replaced ignition switch
-replaced voltage regulator
-checked and rechecked all fuses.
-wire brushed my connections and checked for corrosion.
PLEASE point me in the right direction. I'm think maybe the coil's bad. Anything insight would be GREATLY appreciated!
-jonathan
 Post subject: .
PostPosted: Sun Jul 29, 2007 4:09 pm
Try marking all wires leading to fuse panel. Pull the panel, soak all the leads in 100% lemon juice.
Could be bad contacts. OR a ground somewhere
FIAA: Color Guard
PostPosted: Sun Jul 29, 2007 4:41 pm
PITA Old Fart
Have you checked your fuseable links at the battery?
PostPosted: Sun Jul 29, 2007 5:21 pm
No I didnt know it had any fusible links. I looked them up in the index of the Haynes manual and it just talked about fuses. Thanks, I'll look.
PostPosted: Mon Jul 30, 2007 10:08 pm
multiple clicks means the starter solenoid is bad, one click means your starter isnt even gettin any juice from the bat.check your bat voltage. check for correct polarity, check to make sure red cable is going to starter, and black is going to ground, make sure their clean, check for the green wire from starter to ig switch, make sure its tight and clean.
PostPosted: Tue Jul 31, 2007 2:12 pm
That's a good list of things to check-thanks a lot. I know the battery is charged. I'm gonna print this page out and take it out to the truck and go through each suggestion. Thanks alot for your help guys. :)
PostPosted: Tue Jul 31, 2007 6:25 pm
No starter clicks, no headlights, no blinkers, no nuthin? If the battery is charged, then you are not getting anything to the truck. Battery cables/connections clean? I mean shinny metal clean? Check for voltage on the battery post itself, then the battery cable end, and then the starter end, etc. I'm sure you will find it missing somewhere.
Do this with the headlights on to make a load.
PostPosted: Tue Jul 31, 2007 7:32 pm
well my headlights dont work, but my left blinker will turn on and stay on, no flashing though. the right blinker doesnt do anything i believe. it clicked one time when i put on the new ignition. its screwy. thanks for all the suggestions-im gonna work on it tomorrow and keep ya posted
PostPosted: Wed Aug 01, 2007 8:55 pm
if you have the type of battery terminals that clamp to the wire, take them off and clean in there too. i bought a car once and someone had painted the red terminal off of the wire and the contact part got covered in paint so it had a horrible connection.
1980 luv 1.8 finally running!!!...... and then like a moron i sold it :(
got another one!!! 1980 mikado. v8 swap here we come... nope divorce and cross country move happened.
got another one!!! 1980 4x4 mikado sport. rusty beater for now...
PostPosted: Thu Aug 02, 2007 12:41 am
Well I cleaned every ground I could find and she started right up! Thanks alot for all the help guys!
PostPosted: Thu Aug 02, 2007 3:30 am
PITA Old Fart
Don't you just love it when it all works out with just a little time and elbow grease? :)
